David Vizard Cams - Team Camaro Tech
Thread Tools Display Modes
Old Aug 4th, 03, 07:33 PM
Yellow68SS Yellow68SS is offline
Post
I am going to order a cam next week but not sure on the specs. Every time i talk to comp or crane the cam they recomend is different. I was also thinking of a custom ground cam. I read about david Vizard and his computer program and it sounds good but I still wonder. Has anyone used his service and was it as advertised, the ideal cam.
Kyle
68 Super Sport
468, 11.5:1, AFR 305cc heads, Vic Jr, ProSystems 1000, 264/275@0.050, TH-400, flashes to 4800, 3.73's.
60' 1.55 (gotta work on this)
1/8 6.54@107.5
1/4 10.21@ 132.6
Old Aug 4th, 03, 09:30 PM
mutant 68 mutant 68 is offline
Unhappy
I did not use David Vizard's web site to inquire about a cam.
I talked to the company who uses his computer program (I can't recall the name) wich means that they should end up with the same results cause all they do is punch the numbers into a computer program and let the program sort it all out.
The result for my mostly street car with S/R Torquer 202/160 heads with pocket porting on a 350 with 10.2 compression......650 LIFT and way more duration than I wanted
Then they tried to talk me into a Comp Cams XE HYD after I told them I wasn't interested in having the "custom" cam ground.
Old Aug 4th, 03, 09:53 PM
19Nova72 19Nova72 is offline
Angry
Mayby try calling ALL of the big cam manufactures and getting a recommendation. Then put all those together and pic the cam in the middle. [img]graemlins/thumbsup.gif[/img]
1972 Chevy Nova 357cubes
Old Aug 5th, 03, 02:00 AM
pdq67 pdq67 is offline
Banned
Smile
Go over to Pat Kelley's great "Dynamic Compression Ratio Calculator" site that you can get to from his sig., read it and then play around with it as a start.
May prove very helpful, plus come back and ask what everybody thinks about your cam choice when you get one you like.
pdq67
Old Aug 5th, 03, 02:33 AM
RickD RickD is offline
Post
I tried emailing to David on his website but the message came back as invalid. I think the company is Motor Machine and Supply? What specific specs did they recommend?
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
Old Aug 5th, 03, 01:08 PM
MAT MAT is offline
Tech Team
Post
Either the program, or the data entry people, are on crack.
Recommendation for strip /strip Dart CNC oval port head 10.2:1 3500lbs and 4500 converter - 286/294@50th with 826"/765" lift on 116th centerline installed 8 degrees advanced.
YUP - that'll do just nicely, GACK!
MA
Old Aug 5th, 03, 02:25 PM
Post
Thats what they said would work the best? How could that even be close to streetable? do you have to tell them what RPM range you want.
It seems like everyone says too radical or too mild never in the middle, whats that about. I have had cams reccomended that were from 250@ .050 to 276 @.050 The 276 came from Afr themselves which they say in tere website you can run a smaller cam and make the same power as others heads so i dont know.
Kyle
68 Super Sport
1/8 6.54@107.5
1/4 10.21@ 132.6
Old Aug 5th, 03, 06:16 PM
sik68 sik68 is offline
Steven
Post
Camshafts are all a guessing game. When it comes down to it, a cam selection is based only on past peoples experiences. I computer program had its programmers who were writing programs that guess (albeit with a lot of data in their hands) what a cam will perform like. I believe that choosing the exact perfect cam for a situation is impossible, and a best guess can only be found through pouring over tons of relevant data.
I think a better way to go about picking "the right cam" is to choose a cam you think is suitable, and research the behavioral characteristics it will give in your car. In other words, get a theoretical baseline, and go from there. Not even the NASCAR guys all choose the same cam, so you wont. It's best to just be content with a cam that will produce what you want out of the car.
1968 Camaro
355, Comp XR236R Solid Roller, Air Gap, Pro Systems Double Pumper,
TKO, 10lb flywheel, 3.73 rear, Global West Suspension, Corvette C5 brakes
3098 lbs (and falling!)
Old Aug 5th, 03, 06:29 PM
Post
I choose my first cam myself after thinking what i wanted and reading as much as i could about it. Well now that the car is running have tuned and tuned this thing and cant get it to run how i know it should, the plugs run a consistant tan and the timing is what feels strongest, i know i need a dyno or trap speeds to do the tuning with but both are about 3 hours away and i dont believe it will get the car to where it should be. so the cam is the only thing i can think of that could cause this.
My cam right now is 310 adv 264@.050 on both int/exaust and .590 lift. The other thing i dont understand is this cam is extremely easy to live with on the street. This thing idols at 900 rpm with a lope but smooths out at about 1200 and it pulls great from about 3000 to 6500 The claimed range is 4500-7500.
Most the cams reccomended have less adv dur and about .630 lift but about the same dur. @.050
What do you guys think
Kyle
68 Super Sport
1/8 6.54@107.5
1/4 10.21@ 132.6
Old Aug 6th, 03, 12:40 PM
67RS502 67RS502 is online now
Post
David Vizards cam program works mainly of off "overlap" - lobe separation.
Also the lift that is given is the "ideal" lift, which most of the time is unreasonable.
But he also does cams for Pro Stock guys, so there has to be something there.
I still think every engine is different, and the only way to know what works the best
is to stick it on a dyno, and throw a bunch of different sticks at it! [img]graemlins/clonk.gif[/img]
67 camaro
420 - 641hp HRcam 1.39, 9.79 @ 137.5
502 - 626hp 252/263HRcam 1.44, 10.08 @ 132.7
62 Nova
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
  #11
Old Aug 9th, 03, 10:36 AM
LYK2ROC LYK2ROC is offline
Jeremy
Post
MA
Jeez, MAT, I hope you didn't have to pay for that program or call!! [img]graemlins/clonk.gif[/img]
69 Camaro Finally restored. New 496, 700R4, 3200 stall, 3.90 12 bolt posi
http://www.youtube.com/watch?v=vLd6_OZRgCw
http://www.youtube.com/watch?v=tBr--6yBuXM
http://www.youtube.com/watch?v=Xo0SOSKb1NM
Team Camaro Tech > All Generations > Performance      Current Topic: David Vizard Cams
Location
Location
First Name
Human Verification
