| Team Camaro Tech Current Topic: 1969 Camaro 396 with a 10 1/2 inch clutch | ||
Can I use a 10 1/2 inch FLywheel/clutch assy. and a Bellhousing P/N 403 10 1/2 inch also with a 396 engine? Thanks Team Camaro
| Sponsored Links | ||
Advertisement | ||
Sure!
You will just need to use the 153 tooth starter. It has the bolt pattern that is across from each other and not staggered diagonally
Remember,I'm not making this stuff up! 1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown 1968 Z/28 crossram- j/l8 conv pw,ps,foldown 1963 nova ss 350/4spd conv a/c,ps,pt 1963 nova 400 4dr 6cyl/700r4 a/c 2006 GT/5spd mustang conv |
Thanks, When I go to Auto Zone what Starter do I ask for? Small Block for a 69 Camaro???
Pretty much but take a look at it. When they bring it out, look at the two mounting holes like John said. If they are in a line parallel with the face of the starter, it's the one you need. It'll also use one long mounting bolt and one short bolt. If the mounting holes are offset, it's for a 168 tooth.
I've been trying to turn everyone on to the one I have which is a third of the weight of a stocker but has twice the cranking torque. http://cgi.ebay.com/ebaymotors/NEW-C...Q5fAccessories
'69 Camaro X11 Street Car Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III TKO-600 - Moser 3.42 - Detroit Truetrac 538 lb-ft - 500 hp www.cmengines.com '69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10 '02 Z/28 vert - stock |
| Sponsored Links | |
Advertisement | |
