| Team Camaro Tech Current Topic: Swapping engines, problem matin TH 400 | ||
| Engine General Engine Discussion. |
I switching out the 86 Chevy 350 with a 76 Chevy 350 4 bolt main. Should my TH 400 just hook up to it ? I noticed the top bolt is different on the bell housing, but thats it?I have the tranny on the pins on the block but the torque converter is already contacting the flex plate and not yet bolted in ? ^Thanks
1968 Camaro RS . 350/ TH 400 Yellow/ black stripes |
| Sponsored Links | ||
Advertisement | ||
Be sure to rotate the TQ while you push it to the rear. It has to engage its pump. It will move back. If it doesn't and you tighten the bell housing bolts, the trany will be toast.
One owner 69 Camaro,(yep, bought it new )RS SS Hugger Orange, L88, 4:10's tru-tack posi, ducted hood, Endura, spoilers. TH400 (CX) GV with Coan 8" converter, GV-OD, 8 track still on console and best et 10.617, 126.45mph 1.478 60' All with 1960's stuff. (except tires and converter) + MT Super Scavenger headers. 1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too. ![]() http://epitomesrebuild.com/ |
Thanks Fred, I did rotate it and TC did go back further. I tightened up the housing bolts and it pulled in smooth, no resistance. Bolted up flywheel to flexplate / flywheel. No fluid in tranny. Now when I rotate the crank should the tail shaft on the tranny move also ? Cause ITs not
No, It won't turn that way. The torque converter is turning a pump that pressurizes fluid. That pressurized fluid turns the gears. Maybe if you can turn the Torque converter fast enough and long enough, it may turn... If you have fluid in it.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1 |
Yep, put a quart in TC, and I can barely get my hand behind the TC inbetween the bellhousing, so I assume its in there!
I doubt you can turn it 500+ rpm's by hand... let your engine do it.
with the torque converter unbolted from the flexplate and shoved all the way back into the trans, you shouldn't be able to put much more than a finger between the converter and trans housing.
you don't plan sincerity. you have to make it up on the spot. wanna hear about 20 years ago when i was too smart to know any better? |
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797Z..... |
but none of this has anything to do with what is being asked here.
![]() Larger Dave |
#11
i only see two bolt holes and 2 dowel pins lined up..
| Sponsored Links | |
Advertisement | |
