New Noise... - Team Camaro Tech
Old Jul 19th, 09, 07:35 AM
Miikeremains Miikeremains is offline
Mike
Default New Noise...
Last night I took the car out for a spin and when I was coming to a stop, I heard what I can only describe as a cardboard box dragging under the car. I only hear it from maybe 5mph-0mph on deceleration. It stops as soon as the car stops.
Ring & pinion was set up last week...
SB, M21, 12 Bolt 3.73
Any ideas?
68 SS 357, AFR, Hotchkis, 4spd, 3:73
Old Jul 19th, 09, 08:37 AM
Skeeter55's Avatar
Skeeter55 Skeeter55 is offline
Skip
Default Re: New Noise...
Are you sure its not a worn out brake shoes in the rear... Can you raise the rear and spin it by hand to pin point the noise.
I NEED TO HIT THE LOTTERY
Old Jul 19th, 09, 02:07 PM
Everett#2390's Avatar
<Jake 68's Rule
Maybe there is a cardboard box draggin'......
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Jul 19th, 09, 07:33 PM
Alabamcam's Avatar
Alabamcam Alabamcam is offline
David
Yep, sound like a rear brake to me too. Depress the emergency brake and release it a few times (and I hope you have one), this will usually true up the rear brake form.
1967 RS/SS 4K
1967 RS D-2 Z/28
1967 Pacer 4P -
1968 RS/SS L35 Conv.
1969 Z11
Old Jul 20th, 09, 12:21 AM
mkpatrick mkpatrick is offline
Mike
I adjusted my rear brakes too much.
Now it sounds like I have piece of cardboard dragging.
Drive slowly between some parked cars or up against a building with the windows down, you will hear the cars noises MUCH more.
That's what I do and it echo's the noise back to you.
I'll bet that noise is there at other speeds too, you just don't hear it till its slow.
Same noise I heard with mine. Cardboard.
