LH Tail Light will not working 68 Camaro - Team Camaro Tech
Thread Tools Display Modes
Old Jul 20th, 09, 08:06 AM
Fastbowtie Fastbowtie is offline
Tech Team
Default LH Tail Light will not working 68 Camaro
1968 Camaro RS
I have a problem with my LH tail light. When I turn on the running lights the tail light does not work, however the brake and turn work normally. I have a set of LED's in there as well. I was in an accident and the car was just completely repainted. Everything worked perfectly before the accident. Also when I unplug just the stoplight on that side the running light starts working. Does anybody have any ideas on what would make the running light not work with the stop light plugged in?
Old Jul 20th, 09, 08:24 AM
Skeeter55's Avatar
Skeeter55 Skeeter55 is offline
Skip
Default Re: LH Tail Light will not working 68 Camaro
Can you check the light bulb socket and grounds. Make sure the pins in the socket are pushed all the way in the socket also check all grounds in the trunk.
I NEED TO HIT THE LOTTERY
Old Jul 20th, 09, 08:27 AM
Tech Team
I have cut the socket out and wired them direct with a lead going to the tail lamp nut for ground. Where are the grounds in the trunk I found one on the back by the gas cap on the inside of the trunk. I replaced the end on it.
Old Jul 20th, 09, 08:30 AM
Skeeter55's Avatar
Skip
OK have you tested that socket with a test light and have you check the harness further up in the driver side quarter panel. Are you sure you did cross a wire.
Old Jul 20th, 09, 08:49 AM
Tech Team
I did not check further up the quarter panel yet. You mean to check it at the splice right? Also I forgot to mention that the LH sidemarker light right next to it functions correctly. It is also brown and in the same splice. The guys at my work seem to think it may be the LED board. As for the wire crossing no. I checked it both ways. When you cross them the tail light stays on bright like the brake light.
Old Jul 20th, 09, 11:29 AM
Musclerodz Musclerodz is offline
If the brake and turn function normally, then the LED should be fine. Check for a bad ground or connection in the running light circuit.
Old Jul 20th, 09, 12:03 PM
Tech Team
Ok I will check this tonight. Thanks.
Old Jul 21st, 09, 05:37 AM
Tech Team
Ok this is weird. I found the problem. Since I was using LED's the body shop guy found that one of the lights was not plugged in with a bulb (the rally sport has 4 sockets for the turn and brake lights)so he added a bulb to the system with the LED's. When I removed the bulb the LED's work normally. Problem fixed but not how I thought it would be. Thanks for your help guys.
Old Jul 21st, 09, 06:28 AM
Paulcamaro Paulcamaro is offline
Paul
68 Camaro. When I turn the headlights on the tail lights appear the brightest, actually looks like the break lights are on, because when I touch the break pedal there is no further illumination. When the head lights are off, and I touch break pedal, rear lights go on but not full illumuantion. Any ideas?
Old Jul 21st, 09, 06:39 AM
Tech Team
Are the wires switched? Also re check all your grounds. Do your turn signals work the same way (dim)?
  #11
Old Jul 21st, 09, 10:19 AM
Paul
Turn signals work appear to work the same way. Where are all of the ground wires to check? I will look at it tonight.
  #12
Old Jul 21st, 09, 11:15 AM
You have the brown wire swapped with a green wire or yellow wire or both.
  #13
Old Jul 22nd, 09, 02:46 PM
Paul
I switched the wires, all is well. Thanks.
Tags
light, park, stop, tail
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Electrical & Wiring      Current Topic: LH Tail Light will not working 68 Camaro
Location
Location
First Name
Human Verification
