Brake Pedal turns on Lights in the Front - Team Camaro Tech
Old Aug 1st, 09, 01:45 PM
blumarln blumarln is offline
Tech Team
Default Brake Pedal turns on Lights in the Front
Is it normal for lights in the front of the car to turn on when the brake pedal is pressed? The car is a 68 RS/SS, and the front end lights that turn on are the under bumper lights. Any help is appreciated.
Old Aug 1st, 09, 01:51 PM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is offline
Mike
Default Re: Brake Pedal turns on Lights in the Front
That is not normal. It is most likely a ground issue. Make sure the grounds are good on the front lights.
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/home/pro...maro/allalbums
Old Aug 1st, 09, 02:07 PM
68 Ragtop 68 Ragtop is offline
James
Check your 4 way flasher switch and circuit.
Old Aug 1st, 09, 04:32 PM
Tech Team
Will check these things out, thanks guys!
Old Aug 1st, 09, 05:02 PM
JimM JimM is offline
Jim
Did you just reassemble the car after painting the trunk?
I would ground the tail lights. I like to put a star washer under 2 of the securing nuts, they will cut into the paint and ensure a good ground.
Old Aug 1st, 09, 06:08 PM
Tech Team
No, actually just got the car, but a friend of mine told me about this so-called "common problem." I will check out all of these and any other possibilities and let you all know what I find.
Any recommendations on books where I can find wiring diagrams or shop manuals that make working on these cars any easier?
Old Aug 8th, 09, 01:10 PM
Tech Team
Just wanted to thank you guys, it was a combination of a bad flasher relay and rear light sockets. Replaced all with new and now all the gremlins have disappeared.
