can you guys walk me thrue normal to rs grille conv - Team Camaro Tech
Body Shop Paint & Body Forum
Old Aug 10th, 09, 04:36 PM
SPEEDSHFTR SPEEDSHFTR is offline
Tech Team
Default can you guys walk me thrue normal to rs grille conv
i have a base coupe 68 camaro/im building it up in a pro touring style and need help with the grille switch/i bought the grille from belair bob along with the rs fender brackets.im getting ready to start the install and see where you must cut the original mounting tabs off the inside of the front fender.i tried to hold on one side of the headlight pod and it looked like i needed tocut some of the inner fender?well out a touch.can you guys pull me thrue this one and show me in what order to do the install.id love to pay someone to do the job but the funds are extra low at this time/thank you everyone.hopefully you guys can share some tips or tricks with me
Old Aug 10th, 09, 05:01 PM
Skeeter55's Avatar
Skeeter55 Skeeter55 is offline
Skip
Default Re: can you guys walk me thrue normal to rs grille conv
I don't think you need to cut the inner fender just the existing tab and possibly some bending of the existing tab.. What you should do first is dry fit the RS tabs on the fender and attach them temporally with some clamps to help mock up the light housing vrs the grill. This will take some time and patients to get the best results.
I NEED TO HIT THE LOTTERY
