| Team Camaro Tech Current Topic: 1970 Muncie 4 speed??? | ||
Trying to determine what I need to change to install a 1970 Muncie transmission (P0A05A) with extension housing casting number 3978764 in a 1969 Camaro. The '69 needs a 3857584 extension housing for the correct shifter??? Is this a '70 transmission that had a different extension and mainshaft installed? The mainshaft has the fine splines.
Thanks |
| Sponsored Links | ||
Advertisement | ||
I may be off here, but I don't recall our Muncies having different tail-housings?? What side is the speedo end on?
In and out spline counts are course for the early years and fine for the later years here is all. Jump right in guys.. pdq67 |
I'm not a part number guy, but...
There were a few different muncie tailhousings. firstgens came with a short - pass side speedo. Most everything else came with a short - drivers side speedo. Some big cars came with a long tailshaft. As long as it's a short tailshaft, it will fit. drivers side speedo is actaully easier, just use a speedo cable for that year camaro with a powerglide or t350. powerglide or t350 crossmember and drivershaft will fit. yoke could be different, fine spline muncie's might have a different spline output shaft too (someone will know and post up) fine spline clutch is not a problem, just get one it will fit. The right hurst aftermarket shifter will bolt on to the short tailshaft.
JimM's firstgens.com Camaro Board Jimragtop.com New website for my vert is coming together. Do ya like the slide show on the home page? |
This is my 70 Z28 M21 Muncie, it has various Bosses in the tail extension to mount the Hurst shifter using a base plate mounting bracket original to the 70.
![]() ![]() Note the Mounting Bosses on the tail housing to locate the Shifter's mounting Plate. I know th PIC run out there but I believe you can see most oft it. You should be able to mount this tranny in the 69 and locate the shifter where you want it. I love this PIC ![]() Note the Fan Belt and hoses on the engine - Talk about anticipation ;o)
Z15CAM - There was a Viper in my Rear View This is my 701/2 z28 http://www.flickr.com/photos/28082975@N04 Last edited by Z15CAM; Aug 14th, 09 at 07:52 PM. |
Great picture! Love it!
Chris ![]() 72 Camaro RS/SS, 383, Dart Heads http://i197.photobucket.com/albums/a...ps6f910afa.jpg |
Isn't the 764 tailhousing for the fine 32 spline 70+ trans? It will still fit, but you'll need a different clutch and driveshaft with a 400 yoke.
Correct the Yoke and Drive Shaft length will have to be changed but the Mounting and Shifter Rod length will remain the same.
Z15CAM - There was a Viper in my Rear View This is my 701/2 z28 http://www.flickr.com/photos/28082975@N04 |
The 764 tail extension shifter mount bracket bolt pattern is different than the 584 tail extension shifter mount bolt pattern.
Crashent a member here manufactures a conversion shifter mounting bracket to use a 764 tail extension in a '69 Camaro.
Jody Haag JodysTransmissions@verizon.net Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations 610-682-1602 Auto Gear Muncie Distributor & Builder My '70 Chevelle: ZZ502/502 ROD 6 Speed |
| Sponsored Links | |
Advertisement | |
