How To Pull OBD1 Codes on a 95 - Team Camaro Tech
Fourth Generation 1993-2002
Thread Tools Display Modes
Old Aug 19th, 09, 08:33 PM
Xcelr8 Xcelr8 is offline
Tech Team
Chris
Default How To Pull OBD1 Codes on a 95
I have been searching the posts here to find out how to pull codes on my 1995 that has the OBDII 16 pin connector. The only link that I have found so far is to the BAT website that shows how to jumper a 12 pin connector for the OBD1 setup. Anyone have the link or know what two pins I can jumper to read my SES light?
Old Aug 20th, 09, 09:20 AM
john68 john68 is offline
John
Default Re: How To Pull OBD1 Codes on a 95
Pins A & B, you can read the flash codes
Old Aug 20th, 09, 11:10 AM
hereitis67 hereitis67 is offline
bill
heres a link for you.
http://www.troublecodes.net/GM/
Old Aug 20th, 09, 12:17 PM
Tech Team
Chris
I have the 16 pin connector which I believe the pins are numbered. There is no pin in my connector that would compare with the "B" pin in the 12 pin connector.
Old Aug 20th, 09, 12:19 PM
Tech Team
Chris
Thanks, but I have already checked this site. It only gives details about the 12 pin connector, not the 16 pin one that I have.
Old Aug 20th, 09, 02:01 PM
bill
the 16 pin connector is obd2. you need a scan tool to pull codes out of it.
Old Aug 20th, 09, 02:08 PM
Vintage 68's Avatar
John
Thumbs up Re: How To Pull OBD1 Codes on a 95
- if you don't have or want to buy a OBDII scanner, go to you local chain parts store and they will pull the codes for you and give you a list ...
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Aug 20th, 09, 05:54 PM
BAMiller BAMiller is offline
Bill Miller
Some 1995 cars were built with the obd2 connector but had obd 1 systems. The parts store is a good idea.
1969 RS convertible 327 1981 Z28 original unrestored http://photobucket.com/albums/a95/bamillerstingray/
Old Aug 20th, 09, 06:06 PM
JimM JimM is offline
Jim
He had another thread on this.
It's a 95 GM car, it has an ODB1 computer with an ODB2 harness and connector.
It's gonna be a beetch to read.
Old Aug 20th, 09, 06:28 PM
Vintage 68's Avatar
John
Talking Re: How To Pull OBD1 Codes on a 95
Yup - all 1995 GM cars sold originally in California, and a few other places, that required tighter smog emissions controls.
This was refered to as OBD1.5 by some sources
Now the fun part - almost all good OBDII scanners will actually read the codes from them.
The 'catch' is you may not find the a pre-programmed screen for that vehicle.
No biggy, just go to the set-up screen and manually enter the year and vehicle info and then do a scan - viola it will read the codes, and you can print them out if you have the interface, like places like AutoZone and the other do ...
Iffn' the new-kid at the local parts place doesn't know how his scanner really works, this is a great opportunity to 'edjumacate' him with the above procedure - and he'll probably be the manager next time you go back
My scanner will read all OBDI and OBDII codes - depending on the cable you use.
The software is updatable over the net every year also.
Hope this helps.
1968 Convertible
Some trucks
  #11
Old Aug 20th, 09, 06:31 PM
Jim
I could never get that far. Plugged it into a 95 sunfire, it said nuttin but ERROR
  #12
Old Aug 20th, 09, 09:22 PM
Tech Team
Chris
Thanks for all the input fellas. I do have an OBDII scanner that would not read the codes, it would just give me the error message. It is a basic Actron model, and the instruction manual doesn't cover any reprogramming so I don't think it is possible with this model. I did call my local Autozone and they told me they had two ways to read codes on a 1995. Since it was a transition year they have a "key" that will read the codes if the OBDII scanner won't. I just assumed that the "key" they were referring to was a jumper that would flash the codes and was trying to save a trip to the store if I could jumper the two correct pins myself, but maybe it is not as simple as that.
Team Camaro Tech > Generation Specific Forums > Fourth Generation      Current Topic: How To Pull OBD1 Codes on a 95
Location
Location
First Name
Human Verification
