new vibration - Team Camaro Tech
Old Aug 21st, 09, 04:09 PM
68bigblockSS 68bigblockSS is offline
Tech Team
Default new vibration
alright i just put on a new transmission cooler and transmission mount and when i took it for a test drive i had a vibration at around 2000 rpm or so. it was so bad that i thought one of my new wheels had come loose. turns out that the vibration is there even in park when i slowly increase rpms. the motor is a 468 and the trans is a th400 when i pulled the old tranny mount it was destoryed so i put in a new energy suspension mount. could the poly mount possibly vibrate that bad?
Old Aug 21st, 09, 04:31 PM
Skeeter55's Avatar
Skeeter55 Skeeter55 is offline
Skip
Default Re: new vibration
Man that sounds like a Flex Plate is lose or the Harmonic/Balancer is breaking apart...
I NEED TO HIT THE LOTTERY
Old Aug 21st, 09, 04:41 PM
Everett#2390's Avatar
<Jake 68's Rule
Place a 2X4 across the trans oil pan, nubolt the trans mount, jack up the trans about 1/2-1 inch.
Is the vibration still there? If so, see Skip's suggestions. If not, then the pad is hard and does not absorb vibrations.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Aug 21st, 09, 06:02 PM
Tech Team
ill try a cheap 5 dollar rubber mount and see if it goes away.... it was running perfect before.
Old Aug 22nd, 09, 06:22 PM
Tech Team
well i put the rubber mount it and the problem is gone... seems most people have very little problem with the vibration of a poly mount but i guess mine was an exception.
Old Aug 23rd, 09, 07:39 AM
<Jake 68's Rule
Something may still be amiss in the balance dept.....
