| Team Camaro Tech Current Topic: Camaro roof panel, unibody info needed | ||
| Tech 2000 Our previous General Forum Replies ONLY - no new topics. |
Nice forum! I'm a newbie here. I currently am starting a resto on a '69 sport coupe. The car had a vinyl roof, and when I tore it off, there were HOLES everywhere. The largest one you can stick your finger in. What angle of attack do you recommend? Should I attempt to patch the worse areas with sheet metal, or can I just peel off the outer sheet metal, and TRY to find a replacement?
The guy who had it before me treated it to a telephone pole, so I need to get a new subframe. The passenger side floor buckled slightly, but I plan on replacing the floors anyway. Another quick question...it pushed back the frame boss under the seat brace about 2 inches. Will a frame straightener be able to save it? I heard that laser straighteners do wonderful things. Do you think I will have sheet-metal alignment problems afterward, or is a laser-straightener very accurate? Thanks in advance, and Happy Thanksgiving. I will check back soon for a response. Kind Regards, Manson (no relation to you-know-who) |
Hi there the only way to fix rust is to cut out the rusted area the weld in new and since it's a roof going from the inside and useing a mig welder with weld thru primer.Be carefull not to much heat, or you will have a bigger problem. As far as laser systems I have one and it has been in the box for nine years.I have much better luck with my continental/chief universal measuring system you can get info from old books and see for your self its right and if you cannot find a sheet for you car you could take measurements your self from side to side or off another camaro and any thing the frame bolts to has to be right or nothing will fit.With a laser if you are off a 1/8 at the rear by the time you get to the front its inches, and don't forget older cars had alot more to play with than new ones such as an older chrysler product allowed 3/8 of an inch while the new lexus is only 1 mil.So stay away from lasers. In plain langage they suck!And if you really want one you can have mine for 5 cases of budwiser.Oh yea I just sold a 66 corvette and it had frame damage from twenty years ago I got ahold of some measurements and set it up on the bench and fixed all kind of stuff it was great! Good luck!
5 cases of bud huh? What kind of laser? I love the cheif genesis 2 we have. got the bud in the fridge.
I would have to look but I can tell you it's no genesis, I think its a blackhawk,and oldIts good for lining up a fence and thats about it. The genesis is a good system for that matter I have used caroliner and it is impressive. I got stuck with this junk when I bought my shop so I am a bit soured on this unit. If any of you In the trade have a chance to take the lexus or toyota course do it, there are many courses and I would recomend all of them. The color course is great they unlike any other course you take is not given by someone selling paint so they spend the time on color theory and not how great there product is and that cuts a lot of bull out.You must have a hell of a fridge if it can hold five cases.
Hey, Thanks, Chris! I appreciate you taking the time to answer me. The internet is a wonderful tool to begin with, but when you couple it with die-hard camaro fans, it's PRICELESS!
I will take you up on the 5 cases of Bud, regardless! I am in Clark, N.J. There aren't too many nice 69's around here like there used to be. Hope I can change that notion, before next spring! I have another (intact)69 body to play with, so I'll be taking the 350, M-22 and 12 bolt 3.55 out of the 'crunch-wagon' and popping into an intact one, for now. Kind regards, CHEVY RULES... ![]() |
OOOPS Thanks you too Chris, but the original thanks is to AUSTIN...
Cheers, |
