3970014 350 2 bolt main short block - Team Camaro Tech
What's it worth? & ebay discussions
Old Aug 29th, 09, 04:05 PM
bcm66's Avatar
bcm66 bcm66 is offline
Bryon / Big B
Default 3970014 350 2 bolt main short block
3970014 350 2 bolt main short block, combination of stamped code and VIN come back as correct for 1971 Camaro SS from Van Nuys plant (350ci, at, 270hp).
Comes with oil pan, timing cover. Not sure about crankshaft, probably cast, I did not have the pan off, but owner says its a 2 bolt main. Engine was supposedly a good runner. Also includes a pair of 993 heads and a flexplate.
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street.
Looking for 68 Camaro with body number NOR 181016
CRG - www.camaros.org
Old Aug 29th, 09, 05:27 PM
8ballracing's Avatar
8ballracing 8ballracing is offline
Matt
Default Re: 3970014 350 2 bolt main short block
3970014....350...70-76...2 or 4 bolt main
per mortec.com
Might be worth dropping the pan....
8 Ball Racing
Member #120
1969 X77 10 E 69 302 M21 bagged and tagged pics
1969 RSSS rag top 7 E 69 350 turbo 350 pics
1969 Triple Blue 10 D 68 progress
1968 Chevelle 03 A 68 1st Place GM Nationals 08 stock 68/69
Old Aug 30th, 09, 09:36 AM
bcm66's Avatar
Bryon / Big B
Owner says it a 2 bolt, and I have no reason to doubt that. If it ends up being a 4 bolt, it would just be a bonus. I am just wondering what it is worth.
Old Aug 30th, 09, 06:42 PM
theChuckster theChuckster is offline
Banned
Hey Bryon
A lot of variables to consider to get to a wiw range however if it helps i'll share my experience.
I've been researching these since I picked up one a few weeks ago to build since it was cheap. Mine is a '73 014 2 bolt, std bore, 2442 cast crank, coded CLK (73 Z), complete shortblock, pan, intake, flywheel, waterpump, covers, and pulleys for a steal at $30. Pistons/rods are out of it(?). Heads are mia.
NastyZ says:
1970-73 3970014 350 200 300 2/4 LA built Camaro
http://www.nastyz28.com/sbchevy/sblock.php
30th line item from the bottom. I'd also post an info request at NastyZ.com too since a lot more 2nd gen info is available there.
Chuck
Old Aug 31st, 09, 05:34 AM
twozs twozs is offline
mike
^ a 73 z28 engine will have a 4 bolt main 350 with forged internals. so maybe a restamp. it should also be a 010 block being NO camaros were built in LA in 73
Old Aug 31st, 09, 05:40 AM
mike
the motor in question ; a 71 ss 350 motor should have 4 bolt main as most if not all 350 in the early 70s that had 4 bbl carbs had 4 bolt mains. the 71 ss 350 motor was a 4 bbl motor
Old Aug 31st, 09, 07:53 AM
bcm66's Avatar
Bryon / Big B
Thanks for the info Chuck. You sure got a good deal on the one you bought.
OK, when I get it, I will double check main caps. I was just going by what the guy said.
It is supposed to be a CJD code.
Old Aug 31st, 09, 10:17 AM
mike
rpo L 48 engine for 1971 for an ss camaro: CPG - 4 speed... CGR - auto
Old Aug 31st, 09, 11:04 AM
bcm66's Avatar
Bryon / Big B
http://www.nastyz28.com/camaro/camaro71.php#engine
If they are wrong, then I am wrong. They show CJD: 350ci, at, 270hp/SS
