Turbo 400 filter change question - Team Camaro Tech
Thread Tools Display Modes
Old Sep 4th, 09, 03:23 PM
jeffs68camaro jeffs68camaro is offline
Jeff
Default Turbo 400 filter change question
Today i pulled the pan/filter from my turbo 400 for the 1st time. Now im used to fords where the filter is bolted solid against the valve body so im not sure if this thing is correct or not?? The filter hung from a rubber hose on the drivers front and then it had a single shouldered bolt aprox 1/4" going thru a oval hole on it and securing it to the valve body. But even with this bolt tight the filter is at an angle and can move up/down quite a bit. I assume that when you put the pan in that it lays on the pan bottom but it seems to me it would bounce around like mad in there when you go over bumps. Is this correct??? Seems weird to me.
Old Sep 4th, 09, 04:50 PM
Steve69SS396's Avatar
Steve69SS396 Steve69SS396 is offline
Steve
Default Re: Turbo 400 filter change question
That is correct.
'69 Camaro - 427 SBC Dart Iron Eagle 9.325" block, Cola crank, Lunati 6" Pro Mod rods, JE pistons (13.8:1), Hellfire rings, AFR 245 heads, T&D steel body shaft rockers, Jesel belt drive, custom ground 4-7 swap solid roller 274/286 @ .050" with .704" lift, Dart single plane, 1050 Dominator, Stef's #1705R oil pan, NOS big shot, Lemons 2" primary 3-1/2" collector, Coan 9" converter
Old Sep 4th, 09, 07:25 PM
bikedude3 bikedude3 is offline
clayton hicker
thx for posting that.im about to chang mine and would be scratching my head when i found it
clayton hicker
Old Sep 4th, 09, 10:16 PM
Jeff
Thanks!
Old Sep 5th, 09, 06:35 PM
hereitis67 hereitis67 is offline
bill
yes it flops around. if you got a deep pan on it it will have a spacer on top of the filter.
Old Sep 5th, 09, 06:38 PM
Jeff
There was a orangish colored tube that pushed into the filter, is that the spacer? Or do you mean a spacer at the bolt? Im trying to figure out if my pan is deep or regular. Its aprox 2.5" from the lip to the bottom.
Old Sep 5th, 09, 06:46 PM
bill
a 2 inch pan is stock. if a deep pan it would be around 4 inches deep. above filter there would be like a 1.5 -2.0 spacer on top of it.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: Turbo 400 filter change question
Location
Location
First Name
Human Verification
