Big block, Muncie, shifter, mounting plate ID - Team Camaro Tech
Old Sep 8th, 09, 05:47 PM
rad454's Avatar
rad454 rad454 is offline
Louie
Default Big block, Muncie, shifter, mounting plate ID
I took 4 pic's of my Hurst Competition Plus shifter bolted to the plate that attaches it to the Muncie.
Does anyone recognize this setup? I am not sure if the plate is correct and wondering if anyone out there has a pic of their setup/or do you recognize if this is correct. It's in a 69 that has a BB and correct motor mt's, stands and 4 speed crossmember. I know the BB/drivetrain is set 1 inch to the Rt and some pic's I have seen of the aftermarket bracket show 2 small extension ears that may push the shifter to the left, maybe to compensate for the way the drivetrain is set in place.
Thx
69 SS/RS Fathom Green 454 4 speed
Bumper sticker- My other auto is a .45
Old Sep 8th, 09, 06:08 PM
mrmuncie's Avatar
mrmuncie mrmuncie is offline
Lee
Default Re: Big block, Muncie, shifter, mounting plate ID
It doesn't look like the right mounting bracket or the factory BB Hurst shifter set up. Look on ebay and serch BB 69 Camaro Hurst shifter mounting bracket. You should find a repo that will look correct. All factory 69 Hurst shifters have the chrome handle that slides into a pocket and snaps in place. Yours bolts to the the main body.
Lee (in Louisville, Ky)
Second owner 69 SS Camaro 350 A/C Stick
I specialize in Muncie 4 speeds. Rebuilding tranys for 20 years with over 50 Muncies to select from. If your looking for a certian date code I should be able to help.
Old Sep 8th, 09, 07:16 PM
crashent crashent is offline
The mounting plate you have is Hurst part #195-7773, mainly used on 1964-72 Chevelles W/Muncie, and some other applications... But NOT a 1969 Camaro, or any Camaro...
The reverse lever looks like a 1969-74 Corvette W/Muncie...
Hope this helps... Crash
Old Sep 9th, 09, 06:09 AM
JOE58 JOE58 is offline
The 69 Camaro Hurst aftermarket shifter mount plate is the same for BB and SB.
The OEM 69 Camaro Hurst shifter mount plate is not the same for BB and SB.
Your shifter looks ok but looks like you can use a new 69 Camaro Hurst installation kit.
It has all the rods, trans arms, mt plate, etc.
Old Sep 9th, 09, 07:39 AM
rad454's Avatar
Louie
I learned my lesson on this one. If you do not know your part numbers with absolute certainty, don't take anybody's word for it on ebay. This setup was advertised for a BB 4 speed setup, and it does mount on the tranny as the pics show. But I have seen many posts on the shifter position in the tunnel coming through the console that don't line up. Thats the situation here. Thx for the input. I will try the Comp plus install kit.
