Old Sep 14th, 09, 02:24 PM
braz28 braz28 is online now
Erick
Default wanted custom cam grind manufacturer
Looking for a custom camshaft manufacturer, i have purchased from Lazer cams in the past, but i figure they are no longer in operation as i cannot find their phone number.
i am building a crossram 302 with AFR heads, s.b. cams offered by manufacturers are for 350 c.u. and up.
I would prefer a manufacturer who would tailor a grind for my application, like Lazer as successfully done for me in the past.
thanks
Old Sep 14th, 09, 02:41 PM
zdld17 zdld17 is offline
Team Member
Don
Default Re: wanted custom cam grind manufacturer
Best cam grinder I know. Udharold, orginal of the old Ultradyne cams. He hangs out on the Chevelle site. These are steel billet cams with the Everwear iron dist gear.
Call UDHarold here
(662) 562-4933
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Sep 14th, 09, 02:55 PM
vonzipper396 vonzipper396 is offline
Eric
Cam motion made me my last 2 cams.very smart and helpful guys.Others i know have been pleased as well.
69 SS396 fathom green N/A525 833chrysler 4spd 3550# stock suspension 10.11/137mph
Old Sep 14th, 09, 03:41 PM
TJS69 TJS69 is online now
Tom
Talking Re: wanted custom cam grind manufacturer
There is Engle cams also, who has some old school stuff. Such as :
69 Camaro -originally a LM1 car. 327 (on 350 mounts) AT "461" heads, edelbrock, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Sep 14th, 09, 04:20 PM
Steve69SS396's Avatar
Steve69SS396 Steve69SS396 is online now
Steve
Try Douherty Racing Cams http://drcamshafts.com/
They made this roller cam for me with a cast gear.
'69 Camaro - 427 SBC Dart 9.325" block, Crower crank, Lunati 6" Pro Mod rods, Diamond pistons (14:1), Hellfire rings, AFR 235 heads, 4-7 swap solid roller 274/286 @ .050" with .705" lift, Dart single plane, 825 cfm Race Demon, NOS big shot
Old Sep 15th, 09, 05:40 AM
Busted Knuckles Busted Knuckles is offline
Delta Cams in Washington State.
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
Old Sep 15th, 09, 06:02 AM
Team Member
Don
This looks like one of Udharold cores. Small base circle?
Don
TC # 349
Old Sep 15th, 09, 09:39 AM
Steve
Yep, small base circle. Not sure what core they used. I know they got a lot of their cores from Crane and this cam was done last year before Crane closed.
Old Sep 15th, 09, 10:05 AM
SPARKY69 SPARKY69 is offline
Team Member
BILL
doug herbert!!
Old Sep 15th, 09, 10:45 PM
camaroman7d camaroman7d is offline
Royce
I have had cams ground by both Cam Motion and Engle Racing cams. I will happily used either one again. Both were very helpful and "listened" to what I wanted and didn't just try to sell me any grind they had handy.
Royce (NO XQSSS) Bradley
Pictures
Sound Clip
(brief sound clip, 3" exhaust through Borla Sportsman mufflers)
"If you are not part of the solution, then you are part of the problem" Me
Old Sep 16th, 09, 12:16 AM
wildman926 wildman926 is offline
Harold Brookshire "UDHarold" has a lot of championship wins under his belt. Him cams have that famous "cackle".
HERE is his famous 402A7 or 288/296 F10 solid ft in a 496
Walter
69 Chevelle SS
"Walk Softly, But Carry A big Stick"
http://s150.photobucket.com/albums/s86/wildman926/
Old Sep 26th, 09, 06:50 PM
540Hotrod 540Hotrod is offline
Tech Team
JIM
I've been using a custom Engle in my 540 for years. They have always been great to deal with and have a lot of lobes that aren't listed on their website. I worked with Mark Engle directly and he really took the time to listen to me and work out a good combo.
JIM
'67 Vette Pump gas all motor 540", GForce 5 Speed
Dana 60 IRS-3.07 gears
9.90@141.40
http://s129.photobucket.com/albums/p...rrent=Jim3.flv
Old Sep 27th, 09, 05:37 AM
dawg's Avatar
dawg dawg is offline
Harry
ive used schneider cams for custom grinds with great results.
http://schneidercams.com/
also used these guys too
http://www.americancustomcam.com/
Dawgs 69
406 stroker
SIT DOWN-SHUTUP-HANGON
Old Sep 28th, 09, 12:22 PM
camaro434 camaro434 is offline
Tech Team
Greg
Comp Cams will do custom, also Howards Cams which did mine with a small base circle.
