| Team Camaro Tech Current Topic: M-20 leak? From... | ||
I started my engine up several weekends ago. It is mounted in the subframe and the tranny is attached. I can check for leaks real good like this and what do you know, I found one. 1 week after I started the engine/tranny combo I noticed some fresh 90 wt under the M-20, very light layer on the underbelly. Where does this come from? How could this be? The tranny is freshly rebuilt and the only thing I could come up with is the filler plug could have used a couple more turns to get it real tight.
Anyone have a similar leak? Louie
69 SS/RS Fathom Green 454 4 speed Bumper sticker- My other auto is a .45 |
| Sponsored Links | ||
Advertisement | ||
You could put some teflon sealer (any local hardware/plumbing store) on the threads of your drain plug...
Keith 1967 Camaro Bought it in 1994: 230, PG w/ 314K miles! Today: 383, Dart Iron Eagle heads, Eddy Vic Junior, Holley 750 DP--450HP+ Muncie M-20 GM 8.5, 3.73 posi |
If you over filled the tranny it will leak out the front bearing retainer.
1969 Z28 http://www.byjanmarie.com/camaro/Z28.html 1969 Firebird 400 one owner.! http://www.byjanmarie.com/firebird/69.html My new project for 2010 DONE! http://www.byjanmarie.com/camaro/69camaro.html 2002 Camaro SS LE/SLP |
Muncies are nortorious for leaking out the front of the 1" counter shaft bore. Had luck using a non hardening sealer between the bellhousing and the front of the counter shaft.
Paul, I used a sealer on that 1" counter shaft seal you were referring to. I will start the engine and watch the area for leaks. If I see it leaking from that area, I'm going to seal it externally with JB Weld. I'm not taking that tranny apart because of a small leak.
Does anyone know what keeps transmission oil from exiting the front main shaft. There isn't a main oil seal. There is a large thin flat washer but nothing to keep oil from spilling out if it was tipped on it's end
Not too long ago someone posted a solution to this problem with pics and a tutorial. I cannot find it yet. Many posts come up with "muncie" in a search slowing my hunt.
| Sponsored Links | |
Advertisement | |
