| Team Camaro Tech Current Topic: My Van won't start | ||
| Bench Racing Stories, cruising and more. |
I have a 95 Chevy G20 van. I went to start it up this morning, and as soon as I turn the ignition key, I hear a click...and thats it. All the usual dash lights came on and all seemed well, it just would'nt turn over. I measured the voltage on the Battery and got a 12.38v reading
Do you think it may be the starter?
When you buy an American car, you provide work for a man and his family for three months. -Jay Leno Last edited by garfield; Sep 21st, 09 at 04:31 PM. |
| Sponsored Links | ||
Advertisement | ||
I usually turn on headlights and attept to crank if they go out- battery is likely culprit and if the get slightly dimmer probably the starter both need further testing to confirm but it sounds like starter. If the headlights go out it may be shorted -I'd substitue good known battery and see if corrects this.
69 R/S Z/28 302 4.10 X33 D80 late 09C (looking for date coded 12 bolt BU) 69 T/A clonification LS6-6speed under construction 69 Nova SS retirement project 99 Firehawk 64 Chevelle wagon Consciousness: That annoying time between naps. |
Battery post not tight. Loose wire at the starter. Load test the battery as already stated.
Has it given you any warnings prior to this? Or did this happen all of a sudden?
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/8-7.6sec@88mph,1/4-12.1@110mph,Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall 383 IS SOLD! Building a 489BBC http://s90.photobucket.com/albums/k264/pnewell44/ |
![]() I turn the key, and all I hear is a click sound coming from the front right side of the van right where the starter is. The lights don't dim any, the radio and power windows all work normally. the battery still measures 12.37 volts, everything else works fine. THis happened right out of the clear blue sky!
When you buy an American car, you provide work for a man and his family for three months. -Jay Leno |
Can you get a screw driver and jump the two terminals on the solenoid/starter, if it turns over then turn the ignition on and jump the solenoid and it should start. But i would say yeah starter/solenoid is bad or has a bad connection.
I NEED TO HIT THE LOTTERY |
pull battery cables, clean and put back tight.
Dang side post batterys always seem to get loose from there its test at starter good luck jay |
As stated earlier, your battery is only 75% charged, that's the first place I would start to look for a problem.
* It takes a fool or an idiot to first criticize! It takes a wise and intelligent man to first ask why! 1969 coupe under going restification (Almost Done!) |
update????
Sorry this took so long. Turned out to be the starter!
#11
umm at 12.38 volts its about 98.5% charged. May want to check the batteries in your calculator. And if he tried starting it and power was drawn for the lights and radio then you probably wouldn't be quite at full charge.
NEVER argue with a stupid person. They bring you down to their level, and then beat you with experience. |
| Sponsored Links | |
Advertisement | |
