| Team Camaro Tech Current Topic: Heat Riser Valve | ||
| Engine General Engine Discussion. |
Gents, I have a 69 SS 350 and I am in the process of installing a new exhaust system that came with the car when I bought it. Neither the Factory Assembly Instruction Manual nor the Chassis Service Manual shows a heat riser valve on the passenger side of the exhaust manifold. I have read elsewhere that it is required but I am doubtful. Is it required? Thanks.
| Sponsored Links | ||
Advertisement | ||
It is not "required" - unless you live (and routinely drive) in a very cold climate area ...
They were installed on all standard Camaro's from the factory. They are often removed by PO's, or even some shops, when doing exhaust work - specially if they have frozen-up or though not to be no longer needed for owners driving conditions. As for it not being in the AIM - doesn't surprize me (although I can't remember ever looking for this item) at all - lots of routine items were part of sub-assemblies or procedures and are not included in the AIM. The exhaust manifolds were installed at the engine final assembly plant (Flint or Tonawanda) - the Heat-Riser was installed by the Classis Line folks, as part of the exhaust assembly, prior to body-drop. So the installation of this part was probably in their instruction information and not part of the AIM.
1968 Convertible Some trucks ![]() Other V8 things - some of which float Other V6 things - none of which float ![]() Oh yeah, and 1 "Straight-Six" ... ![]() If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Nice answer. Thanks. I am going to install it since I am going for all original.
It's in the Assembly Manual, you just have to know where to look for it - see UPC 6, sheet C6, item #13 (and gasket #14).
JohnZ CRG '69 Z/28 Fathom Green |
Thanks JohnZ!
Your car will start easier and have better drivability with a functional hot spot under the carburetor. I would hook it up if it were my car.
Intake Manifold Heat Last edited by TheDon; Sep 25th, 09 at 06:04 AM. |
yes, for orignality and yes, for where you live!!
I'm not sure if you're referring to me or to glase but I don't think you read the link I provided. Every carburetor manual recommends that a street-driven car's intake manifold should be heated.
Fraso,
what about the shields that go on the passanger side exhaust manifold, I have the one the pipe goes into but have not installed the long one. I guess I should install the long piece while I have everything apart? Last edited by bigsteve; May 22nd, 10 at 08:30 AM. |
| Sponsored Links | |
Advertisement | |
