Echlin #VC-1810 Vac can where to find? - Team Camaro Tech
Thread Tools Display Modes
Old Oct 1st, 09, 05:26 PM
68problemchild 68problemchild is offline
Patrick
Default Echlin #VC-1810 Vac can where to find?
Alot of posts reference this can since its in the vac advance 101 article.
It was not online at napa nor at Summit. Any ideas where to find it?
Its also called a "B28" can.
1968 Convertible L92 VVT project, Hotchkiss lowering front & rear.
http://www.flickr.com/photos/41575483@N07/?saved=1
Old Oct 1st, 09, 05:47 PM
Sauron67MM Sauron67MM is offline
Scott
Default Re: Echlin #VC-1810 Vac can where to find?
GM Parts Direct. There is another source but the name escapes me at the moment.
Old Oct 1st, 09, 05:56 PM
Scott
This is from an article by Lars Grimsrud, 4/19/01. According to John Hinckley , he and Lars concur on most data.
"There are many different sources for these control units. Borg Warner, Echlin, Wells, and others all sell them in their own boxes and with their own part numbers. Actually, there are very few manufacturers of the actual units: Dana Engine Controls in Connecticut manufactures the units for all three of the brands just mentioned, so it doesn’t make much difference who you buy from: They’re made by the same manufacturer."
Old Oct 1st, 09, 06:02 PM
Tom P's Avatar
Tom P Tom P is offline
Tom
Recently went throught the same thing in July - its available:
http://www.camaros.net/forums/showthread.php?t=160705
Originally Posted by onebad82z
Be warned you cannot get a B28 unit from NAPA any longer. I got mine at Autozone under #DV1810.
you are correct! NAPA online says to go your local retailer and the local guys can't get it. Strange since its obvioulsy still available from others.
I ordered the AC-Delco PN from Rockauto; the NAPA VC-1810 canister is also known as GM PN88924985 and AC-Delco #D1312C (aka "B28")
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Old Dec 14th, 14, 10:40 AM
Nodedmolret Nodedmolret is offline
Banned
Very good and*informative*exchange*..*Thank you!
Old Dec 14th, 14, 09:52 PM
COPO COPO is offline
Mark
Both GM and NAPA have discontinued the vacuum advance can. GM D1312C - B28 and NAPA VC1810. I read that Autozone carries them under part number is DV1810.
Had to make a limiter plate for mine to lesson the advance at idle. I'm not using the rubber bushing either
cause I made one from RG 62A coax cable insulation but when the rod hits the limiter plate it makes an
indentation on the bushing and gives me too many degrees. So I had to make another limiter plate.
This one gives me 4.5* at idle without the plastic bushing on the VA rod. So now I have 16* initial without VA and 20.5*
with VA connected at idle with no bushing.
Mark 1970 Z28 M22 - Lunati 20120121 Retrofit Roller Cam
http://www.nastyz28.com/~copo/index.htm
Old Dec 15th, 14, 06:18 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
John
I have a brand new AC Delco B28 in the box you can have for the shipping cost.
Pm me if you want it.
69 Pro Tour - LS3/T56
69 Pro Tour - LS7/T56 (SOLD)
69 LS7 Pro Tour #2(BUILDING)
69 Z28/RS Tribute355/5 Speed (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
69 Camaro 406 SBC/TH400 (SOLD)
Old Dec 15th, 14, 04:36 PM
Lawrence454 Lawrence454 is offline
Anne
it's at Rockauto : part 4V1053
http://www.rockauto.com/dbphp/x,cata...EX_4V1053.html
Also Autozone DV1810
http://www.autozone.com/external-eng...artNumber=true
Arguing with a woman is like reading a software license agreement.
In the end, you ignore everything and click "I agree."
Old Dec 15th, 14, 04:37 PM
Anne
Can't beat a deal like that !!
Old Dec 15th, 14, 05:28 PM
Mark
Hmm where was he when I needed one. I had my Sister pick one up for me at Autozone in the spring from Naples FL before she returned to Canada for the summer.
  #11
Old Dec 15th, 14, 05:31 PM
john68 john68 is offline
John
This post is from 09, a new guy dug up a dozen old posts yesterday "great info"
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Echlin #VC-1810 Vac can where to find?
Location
Location
First Name
Human Verification
