454 Cooling Fan electric vs flex fan help - Team Camaro Tech
Thread Tools Display Modes
Old Oct 3rd, 09, 07:14 PM
jeffs68camaro jeffs68camaro is offline
Jeff
Default 454 Cooling Fan electric vs flex fan help
I have a 454 (aprox 400hp) in my 68 and it came to me with a flex fan on it and a makeshift radiator shroud.. It had the wrong engine stands/mounts installed and once i put the right ones in, the makeshift shroud will no longer fit.
Running a flex fan with no shroud makes me nervous. Doesnt seem like a good idea, seems like an accident waiting to happen. Opinions? Id rather not buy a repro shroud.
Can a BB be cooled with only an electric fan?? I happen to have the pusher model of this fan sitting in my garage http://www.spalusa.com/pdf/30100400_SPEC.PDF#view=FitH
Would this be sufficient?? I dont really understand the spec chart. How would it compare with the flex fan on there now?
edit: i found a conversion calc that shows the 2200 m3h=1294 cfm
Old Oct 3rd, 09, 08:13 PM
Skeeter55's Avatar
Skeeter55 Skeeter55 is offline
Skip
Default Re: 454 Cooling Fan electric vs flex fan help
Jeff you can do either or... If you already have an electric setting there then it wouldnt hurt to try it. I personaly am using a stock 4-core and 7-blade clutch fan non-thermal with a shroud and love it.
I NEED TO HIT THE LOTTERY
Old Oct 3rd, 09, 08:20 PM
1969ProStreetCamaro 1969ProStreetCamaro is offline
David
Jeff, I'm using a flex fan with factory style shroud plus an electric pusher fan as a back up.
David F.
"All I need is a fast machine". Steve McQueen
My Machine: 1969 Pro Street Camaro
468 CID 661 Horsepower Turbo 400
33"x19.50" Mickey Thompsons
Check Out My Camaro
661 Horsepower 468
Old Oct 3rd, 09, 10:11 PM
BlackoutSteve BlackoutSteve is offline
Steve
GM clutch fan is the go. Flex fans are junk.
Instead if pushing air.. they flex! Go figure.
Nov 68 Van Nuys. 327 floor-shift-auto, Frost Green and not much else when new.
http://img233.imageshack.us/img233/3...sychedelic.jpg
http://www.usmuscle.com.au/Forum/showthread.php?t=2840
Old Oct 4th, 09, 08:14 AM
Jeff
They flatten out only at high rpm which is when the fan doesnt do anything anyways....
Old Oct 4th, 09, 08:33 AM
big block rsss big block rsss is offline
Leonard
I have a 67 with a 454 repo shroud flex fan with spacer and a 4 core .It never overheats,aiso running 4:11 gears
Old Oct 4th, 09, 09:10 AM
zlek131 zlek131 is offline
Matt
Almost exact issue recently discussed...
http://www.camaros.net/forums/showthread.php?t=164138
Matt
68 RS & 72 RS/SS
Old Oct 4th, 09, 12:09 PM
Steve
..and when you do need air at high rpm, too bad.
So when you're on the chassis dyno or doing a nice burnout (car not moving) you don't need air flow?
I had a car that would only lock up the clutch in traffic and on the freeway. The clutch knew what it was doing. A flex would have allowed that car to overheat at speed. No idea why airflow at speed was bad on that car, but who cares? It ran cool.
Old Oct 4th, 09, 01:16 PM
markw markw is offline
If you go with a clutch fan make sure you spend the money on a good one. I had a used one come apart and it wasted my radiator. Now I run a 4 core bb radiator, stock type shroud, and this fan...http://www.flex-a-lite.com/auto/html/7-blade-flex.html It works great with 4 core radiators.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: 454 Cooling Fan electric vs flex fan help
Location
Location
First Name
Human Verification
