Muncie Maincase - Team Camaro Tech
Old Oct 4th, 09, 11:13 AM
737IP 737IP is offline
Tech Team
Default Muncie Maincase
I am looking for a maincase for my M20 to replace one that is broken. My current maincase is a 3885010 indicating a 1 inch countershaft bore. My understanding is that the older muncies came with the smaller 7/8 countershaft. Today, someone told me that all M20's came with the 7/8 bore. Can someone set the record straight?
Thanks.
Old Oct 4th, 09, 11:19 AM
Sauron67MM Sauron67MM is offline
Scott
Default Re: Muncie Maincase
I am not a Muncie expert, I look to those with greater knowledge than I and file it.
Quoted from Jerry Macneish:
"The 3885010 case was used in 1966 and 67. One inch cluster pin, large syncro assemblies, the 64-65 Muncie ("325" case #) is a 7/8" pin with small shifting hubs and blocking rings. Bad design."
Old Oct 4th, 09, 11:53 AM
HOGDADDY HOGDADDY is offline
mike
Thanks.
He's wrong!
1967 convertible T-1
Old Oct 4th, 09, 01:53 PM
NHBandit NHBandit is offline
Team Member
Mark
63-65 are the only ones with a 7/8 shaft. There are no exceptions I know of and the guy who told you otherwise is wrong.
Old Oct 4th, 09, 02:59 PM
hereitis67 hereitis67 is offline
bill
this will help you out
http://www.camaros.org/trans.shtml#Muncie
Old Oct 4th, 09, 04:46 PM
bill
also if you need that case i have 1. pm me if you need it.
Old Oct 4th, 09, 05:30 PM
Tech Team
That's what I thought. Thanks for the quick replies.
Old Oct 4th, 09, 06:23 PM
mrmuncie's Avatar
mrmuncie mrmuncie is offline
Lee
ebay is a pretty good place to find what you need. The cases with the one inch bore are 010 660 and 661. If your not worried about build code dates any one of these castings will be fine.
Lee (in Louisville, Ky)
Second owner 69 SS Camaro 350 A/C Stick
I specialize in Muncie 4 speeds. Rebuilding tranys for 20 years with over 50 Muncies to select from. If your looking for a certian date code I should be able to help.
Old Oct 4th, 09, 08:59 PM
Straight-line-69 Straight-line-69 is offline
If you're building any HP at all, now would be a good time to go to the Muncie Super-Case from these folks:
www.autogear.net
Old Oct 4th, 09, 10:51 PM
larryh56 larryh56 is online now
Larry
x2 on the super-case. I put one in my '69 and it is a MUCH better built case - better alloy, full size bearings on both ends, o-ring drain plug, etc. It has a slightly thicker front part so you gain about a 1/2 inch in length if I remember correctly.
68 RS Coupe 327/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
Old Oct 5th, 09, 06:40 AM
JodysTransmissions JodysTransmissions is online now
Yes, the Supercase utilizes a full width 307 front bearing for added strength too. No more leaks at the front countershaft either.
Jody Haag
JodysTransmissions@verizon.net
Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
610-682-1602
Auto Gear Muncie Distributor & Builder
My '70 Chevelle: ZZ502/502 ROD 6 Speed
Old Oct 6th, 09, 08:15 PM
Tech Team
I have been watching these things on Ebay and for what they are selling for you are real close to a new supercase!
Old Oct 7th, 09, 06:17 AM
Most used cases need to be machined for bushings at the countergear shaft to prevent gear lube loss. That service is about $150.00, well worth it if you have a numbers matching case to the vehicle. Otherwise, usually a Supercase is a better buy for non-matching number car.
Most times when you see a case for sale, that case came from an exploded gearset. That could also mean case stretch between the mainshaft and countershaft centerline and that is not good either.
Jody Haag
610-682-1602
