rebuild TH350 or swap to muncie 4 spd - Team Camaro Tech
Thread Tools Display Modes
Old Oct 13th, 09, 06:54 PM
80camarotwntrbo 80camarotwntrbo is offline
kevin
Exclamation rebuild TH350 or swap to muncie 4 spd
Hello everyone, long time no talk... anyways, so my TH350 is having some issues.... driving it the otherday it did fine up until the time i needed to use reverse to do a three point turn. when shifting to reverse it managed to "stay" in drive and only went forward...long story short " P, R, 2Nd, L " all feel like its in drive and i'm standing on the brakes " N, D " feels like straight drive with no issues. Transmission fluid is perfect, shift link is great. should i attempt to rebuild or just upgrade to a muncie to increase fuel economy (same speed lower RPM)
Old Oct 13th, 09, 07:15 PM
Andrew69's Avatar
Andrew69 Andrew69 is offline
Andrew
Default Re: rebuild TH350 or swap to muncie 4 spd
Muncie 4-speed or better yet a Tremec 600 5-speed with overdrive.
Skunk Works
302DZ, M22W Muncie, GV overdrive,12-Bolt Rear 3.73
Some photos: http://www.camaros.net/showroom/show...0&ppuser=11587
Member # 159
Old Oct 13th, 09, 09:41 PM
zlek131 zlek131 is offline
Matt
I would not waste $ on rebuilding a TH350. If your plan is to convert from auto to manual tranny then spend the $ there. If gas mileage is your goal then skip right past the Muncie 4 speed on to a TKO 600. When my TH350 died every shop told me that they will gladly take my $ and rebuild it but for a little more I could have a lot more than TH350 boat anchor. I went with a 700R4 as I wanted to stay with an auto tranny.
Matt
68 RS & 72 RS/SS
Old Oct 13th, 09, 10:59 PM
Z282NV Z282NV is offline
Joe
Hey guys I am thinking about this swap as well. What are the exact steps involved besides buying the tranny? Can you make it look stock with the Hurst shifter?
Z282nv........."its gotta be red"
http://s10.photobucket.com/albums/a130/z282nv/
Old Oct 14th, 09, 05:26 AM
mike's blue67 mike's blue67 is offline
Mike
Joe call classic Chevy 5 speed they are a sponser on team camaro. I used them and my swap was a piece of cake. The technical advice from Jim is outstanding. I have had no issues at all. The OD was a great investment. My 500 HP 406 get anywhere from 15 to 19 mpg where last year with my 302 i got 10 to 12 mpg. Give them a call i dont think you would regret it. Mike
Old Oct 14th, 09, 06:22 AM
sspecialk sspecialk is offline
Scott
The swap to a 4-speed is very straight forward. You can buy the complete clutch setup and there is a ton of info on here and the internet to determine exactly where to cut the hole in the tunnel etc. It is really a bolt on and go thing. In fact if you go with the typical M20 or M21 with the smaller output shaft you should not have to make any modifications to the driveshaft assuming it is the correct length currently. The cross member is the same. You will have to research the speedocable as I had to get a different one for my car but again parts are easily accessible. Good luck and have fun shifting the gears.
A couple of tips to make note of during this is to make sure you get a BRONZE pilot bushing, not the magnetic type most places sell. Also be real sure to index your bellhousing to make sure it is properly aligned so you don't have transmission issues down the road.
Old Oct 14th, 09, 11:06 AM
69 z11 69 z11 is offline
Jerry
I've decided to got to a Richmond 4+1 when I pull my TH350, it's supposed to be shipped today.
69 Z11 03D Van Nuys
82 Z28 Gordon Johncock's Pace Car
97 30th Z28 6 speed vert 1 of 175
A Pair of Huggers at the Car Show
Old Oct 14th, 09, 07:06 PM
Melrose RS Melrose RS is offline
Tom
Forget about gas mileage for a while - you are gonna have too much fun shifting.
'67 rs - ordered new by my Grandfather
327 L30, K-K, Deluxe int, tach & gauges, 12 bolt posi, 4 speed.
the Melrose rs - L30 327/275hp
Old Oct 15th, 09, 01:02 AM
kevin
so everyone then agrees to drop the th350? if thats the case will i need to change my 256 gears in the rear also? and where is a good place to look to get a good manual for my car (mind you i'm running a 350 csb
Old Oct 15th, 09, 03:25 PM
Jerry
Not going to get much off the line acceleration with a muncie and 2.56 gears.
69 Z11 03D Van Nuys
  #11
Old Oct 15th, 09, 04:47 PM
Aaron67 Aaron67 is offline
Look for a four speed with a deep first gear. saginaws went up to something like a 3.50 first gear i think. help me out here guys. and saginaws come a lot cheaper than muncies or T-10's or any of the TKO stuff. otherwise with a close 2.20 or even the middle 2.50-ish first gear, you'll still be feathering the clutch off the line. 2.88 first in my ST-10 and 3.36's or thereabouts in the axle, very little feathering to get moving.
  #12
Old Oct 15th, 09, 05:30 PM
keithl1967 keithl1967 is offline
Keith
I just did the swap form a TH400 to a muncie...not a bad swap at all, and ended up costing me about $2200.00 less than the Classic Chevy/Keisler quotes for their "kits"...
My Muncie was a rebuild I picked up for about $700.00, and pieced the rest of it together with parts from vatrious distrubutor's (Rick's First Gen, Summit, etc)...
Of course, I had to spend a few dollars more that if I already had a TH350, becaus ei needed to pick up a crossmember, and driveshaft...
Keith
1967 Camaro
406, 10:1, comp xr282HR, Dart Iron Eagle 200cc, Holley Contender dual plane, Holley 750 DP
Muncie M-20
GM 8.5, 3.73 posi
  #13
Old Oct 15th, 09, 06:26 PM
Tom
Yup, I'm running a 3.50 Sag with 2.73 rear. Great combo for take off and highway. Super T-10s can be had with a 3.42 first if you need stronger than a Saginaw. Aaron are you sure you really have a 2.56 rear?
  #14
Old Oct 15th, 09, 06:37 PM
must've meant to ask that to kevin... 'cause i got 3.36's, or whatever the 8.2" had that was close to 3 and 1/3 (forgot to count teeth when i had the diff cover off).
didn't the late second gen's come std with some really tall gears? wouldn't be surprised if it was 2.56. oh man, talk about a top end car!!! i'd be dangerous with a car like that on my trips to the high desert haha!
  #15
Old Oct 15th, 09, 09:03 PM
Tom
Yup, sorry. And I was thinking first gen. 2.56 would be pretty unusual in a first gen.
Yeah, I think that's where those Super T-10s were used.
Tags
1980 camaro, camaro, camaro rs, muncie 4 spd, th350
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: rebuild TH350 or swap to muncie 4 spd
Location
Location
First Name
Human Verification
