Repair a plastic center console 68 - Team Camaro Tech
Old Oct 23rd, 09, 07:02 AM
JeffsSS JeffsSS is offline
Default Repair a plastic center console 68
I have an original center console for my 68 convert but it is in rough shape. It has some large cracks and a hole in the drivers side. I want to repair it. I plan on putting something inside to support the cracks so they will not open up again once I have it repaired. It will also be the inside backing for repairing the hole. My bigest problem will be matching the "grain" with my repair. I would also like to know what I should use to fill the hole and the cracks. Can I just use bondo or tiger hair to make this repair? If not what do you guys suggest? I really do not want to buy a new console.
Thanks,
JeffsSS
Old Oct 23rd, 09, 08:09 AM
rj68RS rj68RS is offline
Russ
Default Re: Repair a plastic center console 68
Mine had a couple cracks and I used 2-part epoxy resin with glass mat backing to repair it. For the grain, you might try to find a piece of vinyl that matches and then use it as a pattern from the outside to "texture" the filler just before it sets up. If the filler material is too soft it'll stick and spider web, if too hard you won't get much of an impression.
Btw, the OER interior paint worked great when I painted the finished console.
Russ (RJ)
The Garlic Capital, Gilroy,CA
1968 RS convertible that is not quite stock
Pics: my drop top driver
Old Oct 23rd, 09, 08:19 AM
Sauron67MM Sauron67MM is offline
Scott
3M Rigid Parts Repair. It's a professional product used daily in the collision industry. Excellent performance but more coin than resins and cloth.
