1994 3.4L starter - Team Camaro Tech
Fourth Generation 1993-2002
Thread Tools Display Modes
Old Oct 25th, 09, 04:54 PM
1969SSBB 1969SSBB is offline
Default 1994 3.4L starter
Has anyone replaced the starter on a V6 1994 camaro? I have tried to remove the one from my daughter's car and it seems that the Y-pipe has to be dropped to get it out. In addition, the connections for the solenoid face towards the front and the replacement starters face the rear. I have no reason to believe this isn't the original starter. Any comments? I have replaced many starters on different vehicles but not one this difficult. I am working with the car on ramps so space is tight.
69 Lemans Blue 454 AC PDB PS
Old Oct 27th, 09, 06:40 PM
Default Re: 1994 3.4L starter
Hello? Anyone home?
Old Oct 28th, 09, 04:20 AM
Everett#2390's Avatar
<Jake-68's rule
Rockauto shows a 'front' facing starter. and on some models, the exhaust does have to be dropped.
You might get a Haynes manual for make/model of car and read what it has to suggest.
If old starter has a heat shield, transfer it over to the new starter.
Heat shield: AC/Delco P/N 10468258
Old Oct 28th, 09, 05:09 AM
SPARKY69's Avatar
SPARKY69 SPARKY69 is offline
BILL
Its gravy and you do have to drop the front pipe down!!
Old May 9th, 10, 09:53 AM
tmracing15 tmracing15 is offline
It can be done without dropping the ypipe, not easy but can be done.
Team Camaro Tech > Generation Specific Forums > Fourth Generation      Current Topic: 1994 3.4L starter
Location
Location
First Name
Human Verification
