| Team Camaro Tech Current Topic: flywheel date code question | ||
| Camaro Tech General Tech Area For best results use specific forums |
How does this date code decode?
![]() Thanks! Tom
'67 rs - ordered new by my Grandfather 327 L30, K-K, Deluxe int, tach & gauges, 12 bolt posi, 4 speed. (And an 8 year old riding shotgun. )the Melrose rs - L30 327/275hp |
| Sponsored Links | ||
Advertisement | ||
April 23rd - some year ending in '9'
![]() Could be 1969, 1979 ... Use of the casting number year(s) use/availablity range may help you narrow it.
1968 Convertible Some trucks ![]() Other V8 things - some of which float Other V6 things - none of which float ![]() Oh yeah, and 1 "Straight-Six" ... ![]() If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
I'm just guessing Tom............April 23,1969?
![]() __________________________________________________ __ 1968 Camaro Z/28 British Green, 05B, 712 currently on the rotisserie! |
Must be 69. What does the sundial thing tell you?
The casting number is 3791021.
Actually it tells you what hour of the shift it was cast in.
Yours would seem to indicate the second (or closer to the third?) hour of the shift. I'm not familiar with all the component casting clocks used for stuff like flywheels - there may have been only one shift per day, or they may have used a different screw type to indicate shift... Yours looks like a flat-head screw, which often meant 1st shift, but again, not sure on these units.
| Sponsored Links | |
Advertisement | |
