67 camaro leaf spring question/problem - Team Camaro Tech
Old Nov 21st, 09, 11:27 PM
tekin tekin is offline
Default 67 camaro leaf spring question/problem
ok i had a mono leaf in my 67 camaro, and bought my buddies 69 convert camaro multi leaf rear end. all this stuff is stock
here is what i used of his
rear end and leafs
what i used off mine
mono leaf shock plates
so the question is will i have to buy new shocks or can i use my original mono ones???
also what is the torque specs for the bolts
shock plate bolts( t-bolt and u-bolt)
rear shackles
front spring eye bolt
front spring body mount ( 3 bolts)
and i left everything loose in the car and dropped the rear end already, so let me know so i can tighten it all off tommorrow thanks
Old Nov 22nd, 09, 09:58 AM
keypilot's Avatar
keypilot keypilot is offline
Mark
Default Re: 67 camaro leaf spring question/problem
I use german torque specs on all bolts
gooodentite.
as for the shock question, if you used your shock plates you should be able to use your shocks. the plate changes the location of the shock.
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
499 lb-ft @ 4,800 rpm
www.firstgens.com
Old Nov 22nd, 09, 02:23 PM
but will the difference in thickness of the mono leafs and multi leafs and new leaf pads make a difference at all
Old Nov 23rd, 09, 06:29 AM
can anyone help me on this thanks
Old Nov 25th, 09, 05:22 PM
hello is anyone available to help out thanks
Old Nov 26th, 09, 09:09 AM
Harleyguy Harleyguy is offline
Tech Team
Steve
The stock length shocks with the mono plates and Multi Leaf springs will work just fine.
