| Team Camaro Tech Current Topic: Max 383 Cam Lift | ||
In my new 383, I was wondering what was the max safe cam lift. I figured that with a Comp Cams XE284 and 1.6 rockers, the lift @ valve should be around 540 on both sides. Is this safe???
Combo: Flat top forged pistons (11 to 1 comp) Balanced and Blueprinted Dart Iron Eagle 180 closed chambered heads (I know they're too small) Springs are good to 600 lift Comp Cams Magnum roller tip rockers (1.6 ratio) Holley 750 DP Performer RPM AirGap
A Civic with a turbo the size of your head at 10,000rpm will never sound as impressive as a blown big-block at idle. |
| Sponsored Links | ||
Advertisement | ||
There really isn't a way to find out, it depends on every engine. Factors like valve size, cam lobe design, piston design, deck height, etc. all play a role. But it isn't the max lift that causes problems, as interference usually happens between 0 and 20* ATDC.
I'm in the same boat. I'm moving up to a .600" lift roller cam with a 2.08 valve on my new heads. It's a Herbert cam, and they said if I check the clearance and its not enough, I can return the cam. You just wont know until you dial it in. Ask Comp if you can return the cam if you find it wont work out.
Matt Jones Lead Mechanical Engineer Art Morrison Ent. Inc. |
hey dave rivera...i like the little quote at the bottom of your post!!
'69 SS 350 Camaro (true X55)<br />350 turbo with shift kit<br />3.55 posi rear end<br />favorite Bible verse...all of 'em!! |
Depends on the rods a lot too -- not just the cam.
Generally speaking, the longer the rod the tighter the clearances between the cam and rod get. Most aftermarket rods are designed with strokers in mind so you will probably have more clearance with an aftermarket rod. Capscrew rods will offer even more clearance. Whatever you do just make sure you get in there and measure. I use a coat hanger flattened to .050" on the end as a go/no-go gauge.
E85 racer and E85 carb builder www.horsepowerinnovations.com 68 Camaro, E85 powered 427" small block. 9.96 @ 133 MPH, 1.319 sixty foot on motor. 5.92 eighth @ 116 with a 1.42 sixty breaking beams with back tire on the bottle |
max safe cam lift
Piston to valve clearance is what youre askin about right? It depends on duration of the cam and degreeing it, for the most part.
67 camaro 373s: 420 - 641hp HRcam 1.40, 9.90 @ 135 502 - 626hp 252/263HRcam 1.44, 10.08 @ 132.7 62 Nova 383/200-4R/12-bolt w 373s 224/224 HR cam 1.57 10.97 @ 121.2 |
| Sponsored Links | |
Advertisement | |
