12 bolt gear combo's - Team Camaro Tech
Old Jan 2nd, 04, 05:29 PM
z/27 camaro z/27 camaro is offline
Mike
Question
i've been told that 3:31 gears for a 12 bolt are hard to get. not a common combination.and very expensive.i was under the impression that you could buy a camaro in 69 with this ratio?
i have 3:73's now and want to go to a higher gear set so i can cruise a bit easier. i was thinking 3;31's would be a good ratio.
does anyone know what is readily availible in this ratio area? 3:42's?? whats a common ratio i should be looking for?
thanks
mike [img]graemlins/beers.gif[/img]
69 Camaro RS/SS 350.<br />GM 2.02 angle plug heads.<br />223 dur/480 lift hyd cam.<br />69 z/28 alum high rise.<br />69 z/28 780 vac sec holly carb.<br />4 bolt mains,steel crank,forged flat top pistons.<br />Turbo 350 2800 stall with shift kit.<br />3:73 12 bolt posi.<br />functional ZL2 cowl induction hood<br />gear vender O.D.<br />13.2 in the 1/4 with slicks and open headers
Old Jan 3rd, 04, 03:56 AM
Rookobird Rookobird is offline
Post
I also have a "Z-27" 69. It came with 3.31 gears.
They seem good for cruisin' although my speedo's broke so I don't know the exact RPM's I'm cruisin' at. Probably about 3200 for 65mph-but just a guess.
Mine is a 4sp and I would like to go even higher (3.08) or get an overdrive. I only drive on the street- the race guys like the lower ratios.
John
69 SS350 Coupe, 4 speed- under construction- "resto-mod"
Old Jan 3rd, 04, 04:31 AM
pdq67 pdq67 is offline
Banned
Smile
A car with an M-20, 3.31's and stock D-70/14, 25.3" to 25.5" or so diameter tires will run right at 3075 to 3050rpm at 69.9 to 70mph!
pdq67
