Does timing play a big part when....*please help* - Team Camaro Tech
Old Dec 4th, 09, 08:39 PM
Camaro1969 Camaro1969 is offline
Vic
Default Does timing play a big part when....*please help*
2 questions:
1. would your your timing play a big part of when you try to start the engine? in other words, if your timing is completely off, and starts on occasions, would this be related heavily to timing... after a few cranks of trying, it sometimes starts, it sometime doesnt..
2. with your timing being off, would it cause your flywheel to turn and then spit backwards and rub against your starter pinion, causing a clunking noise?
Vic
1969 Camaro SS
Old Dec 4th, 09, 08:58 PM
1969 RS/SS DROPTOP 1969 RS/SS DROPTOP is offline
Paul
Default Re: Does timing play a big part when....*please help*
Yep sounds like the timing is on the high side if it's kicking back.
Old Dec 4th, 09, 09:01 PM
Vic
so to get it to start, without the clunking, would i advance the timing or retard it?
Vic
1969 Camaro SS
Old Dec 4th, 09, 09:20 PM
Paul
Retard it if it's hard starting and kicking back.
Old Dec 4th, 09, 09:34 PM
Vic
before trying to start it? if i do that, the rotor will move and then wont i have to set it to tdc, and point plug 1 to first cylinder?
Vic
1969 Camaro SS
Old Dec 4th, 09, 10:17 PM
Paul
Point the rotor to the number 1 plugwire on the cap.
Old Dec 5th, 09, 04:22 AM
Andrew69's Avatar
Andrew69 Andrew69 is online now
Andrew
Just turn the distributor a couple of degrees, with the engine off, and then try to start it. Once it runs on it's own pretty well, use a timing light to set the timing.
You should have already done this. If not do it first.
Skunk Works
302DZ, M22W Muncie, 12-Bolt Rear 3.73
Some photos: http://www.camaros.net/showroom/show...0&ppuser=11587
Member # 159 (Formally known as X33D80)
Old Dec 5th, 09, 07:59 AM
Vic
yes its already set to 1, and i will turn it a few degrees, i think it is too far to advanced, causing it to kick back
Vic
1969 Camaro SS
Old Dec 8th, 09, 01:23 PM
deerhunter deerhunter is offline
You could also loosen the hold-down bolt, have someone crank the engine, and turn the distributor by hand in small movements to get it started. After it is running then use the light.
Old Dec 8th, 09, 01:57 PM
SPARKY69's Avatar
SPARKY69 SPARKY69 is offline
BILL
start all over again...get it on tdc, up on number 1 and check your cap and your wires and your marks on the balancer and use a timing light, put it on 16-18 initial and 34-36 total..
