67 Crooked stance - Team Camaro Tech
Camaro Tech General Tech Area
Old Dec 5th, 09, 12:51 PM
67 RS style 67 RS style is offline
Gary
Default 67 Crooked stance
I just put new hotchkis springs, 2" lowering spindles and disc brakes on my 67 Camaro, oh, new 18" wheels too. I can't seem to figure out why the passenger side sits lower than the drivers side? 1/2" lower to be exact. checked the spring seats, they look to be correct, positioning is also the same, I am at a total loss.. and the back is off even more 1" put lowering blocks in the back too... any suggestions?
Old Dec 5th, 09, 01:03 PM
Dan E. Dan E. is offline
Dan Ensign
Default Re: 67 Crooked stance
I would bet the right rear spring is the culprit, did it sit level before you started?
Dan E.
69 SS396 4spd. 4.10 posi. x66 coupe
Old Dec 5th, 09, 01:19 PM
Gary
I don't think it did but quite honestly, I did not measure, bonehead move...but the right read does rub just slightly and the left does not, fits with your assesment, when I bought it, it looked like one of those ICBM missles on a truck,,, ramped up in the front, the front was at 9" to the rocker perfect for factory, but the rear was sitting at 7.5" 1.5" low per the factory spec, also fits... so now the question, how to verify?
Old Dec 5th, 09, 01:20 PM
Gary
right rear rubs
Old Dec 5th, 09, 01:49 PM
Gary
Old Dec 5th, 09, 01:52 PM
Gary
passenger side rear
Old Dec 5th, 09, 02:03 PM
TrueSS72 TrueSS72 is offline
Christopher
Are your blocks seated right?
1972 Nova SS - Dads car in Highschool
Old Dec 6th, 09, 12:08 PM
Gary
as far as I can tell, they look fine... wondering if it could be a spring bushing??
Old Dec 6th, 09, 12:42 PM
William William is offline
Did you final torque all fasteners with the car resting on earth? If the car was on jackstands when torqued there could be some binding.
William
CRG www.camaros.org
Old Dec 6th, 09, 01:18 PM
DOUG G DOUG G is offline
RedЯuM
I would double/tripple check the front springs and that they are seated correctly (tops and bottoms).
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Dec 8th, 09, 11:52 AM
1968 Camaro 1968 Camaro is offline
Tech Team
John
Hello I would swap the springs in the front and see if one of the springs are sagging. Or at least have the springs checked to see the load range. Maybe you got a big block spring and a small block spring from where you bought the parts from. Just a thought.
1968 396 SS Red/Red Deluxe interior.
Been updated to a 460ci
Powerjection 1
700r4
oirginal 12 Bolt.
Old Dec 8th, 09, 12:01 PM
dawg's Avatar
dawg dawg is offline
Harry
check height with you in the drivers side.
seen this on corvettes and maybe this is the same.
Dawgs 69
406 stroker
us navy retired
http://www.northeastf-bodyassn.com/
Old Dec 8th, 09, 04:12 PM
HAD1NHS HAD1NHS is offline
Tech Team
unbolt your sway bar, and see if the car sets level. I've seen several aftermarket sway bars that are not flat. If this is the case you can vary the length of the spacer in the link kit side for side to correct.
Jeff
67 RS SS 383 stroker M20 3:73 12 bolt
74 Z28 100% original 58,000 miles 4speed A/C
2001 Corvette convertible red 6sp 20,000 miles
96 Z28 dealer added SLP 315hp LT1 4a 58,000 miles
98 Z28 SS convertible LS1 6m SLP#1300 12,000 miles
Old Dec 9th, 09, 08:28 AM
rj68RS rj68RS is offline
Russ
Have you driven it yet ? Often times a drive around the block will aid the rear spring bushings to settle. Even though I always tighten my suspension bolts with the cars weight on the wheels, I find a short drive settles things out to the real ride height.
Russ (RJ)
The Garlic Capital, Gilroy,CA
1968 RS convertible that is not quite stock
Pics: my drop top driver
Old Dec 9th, 09, 02:09 PM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is offline
Mike
If it doesnt setlle after you drive it,, then I would be swapping springs from side to side to see if they make a difference.
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/home/pro...maro/allalbums
