| Team Camaro Tech Current Topic: Roller Rockers | ||
| Engine General Engine Discussion. |
I am planning to swap the top end on my sb302, new heads, intake and hyd. roller cam. Any opinions on a brand of roller rockers? Any horror stories? I currently have Cranes since about 88 with no problems but with their demise (not my rockers) what is next?
| Sponsored Links | ||
Advertisement | ||
Comp Cams Magnum roller rockers are reasonable if you aren't running too much lift / spring pressure.
69 Pace Car and 69 Hard top |
David F.
"All I need is a fast machine". Steve McQueen My Machine: 1969 Pro Street Camaro ![]() 468 CID 661 Horsepower Turbo 40033"x19.50" Mickey Thompsons Check Out My Camaro 661 Horsepower 468 |
x2
I NEED TO HIT THE LOTTERY |
Thanks, I was looking at Comp Cams for the cam anyway. The only variable I am missing is the deck height to choose the cam so I am amassing parts.
For a few dollars more , there is the Comp ProMagnum. While you are at it, might check the rocker arm geometry.
Don TC # 349 Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E http://s102.photobucket.com/albums/m...t=115_1577.jpg |
Yes I plan to check the geometry. Likely will need different pushrods with the new heads.
beehive springs will give you more clearance to use the magnum roller rockers from Comp Cams - they work well on most of the hydraulic roller cams too.
im a big fan of crane. i have golds in one car and silver in another. the golds are more expensive and supposedly superior but the silvers have alot more clearance underneath on the stud.
I'm running the ProMags...working fine.
68 Camaro~ LSx RedЯum <-Pics http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here |
#11
promags and stud girdle here.
CURRENT PROJECT: 1969 X66 RALLY GREEN/BLACK COMFORT WEAVE, OWNER INSTALLED RS PACKAGE![]() 1987 BUICK GRAND NATIONAL SOLD 2002 C5 coupe Electron Blue 1 owner FOR SALE FUNDING THE X66 BUILD
#12
same as 1SLOW64.......Comp Pro Magnum w/ stud girdles and no issues what so ever!
#13
Yella Terra pro platinum's, Harland sharp, Scorpion
| Sponsored Links | |
Advertisement | |
