Oil coming out of dipstick tube 350 - Team Camaro Tech
Troubleshooting Diagnosing problems done here.
Thread Tools Display Modes
Old Dec 28th, 09, 10:43 PM
bluefowl bluefowl is offline
gene
Unhappy Oil coming out of dipstick tube 350
bought a car with this motor in it it has 40 lbs oil pressure all times but when idled up oil comes out the tube and all over the headers and driver side engine compartment.the engine has been modified but the guy i got it from knew very little about it.it has high rise intake angle port heads demon carb etc... please help me figure this thing out before i pull my hair out.................. lol
Old Dec 28th, 09, 11:10 PM
gene
Thumbs down oil coming out of dipstick tube 350 2 bolt main
what will cause oil to come out the dipstick tube? i just bought the car and dont know alot about it any help is apreciated
Old Dec 28th, 09, 11:29 PM
Camaro1969 Camaro1969 is online now
Vic
Default Re: oil coming out of dipstick tube 350 2 bolt main
overflow of oil, did you put more than u were suppose to
Vic
1969 Camaro SS
Old Dec 28th, 09, 11:34 PM
R,S-man R,S-man is offline
Tech Team
Gav
Have ya got a P.C.V system from ya filler caps on both valve covers???
If not try taking the filler caps off/out and idle the car to see if the
oil problem is still there,
If so then a compression leak down test to see if theres excess compression
leaking into the sump and pressurizing it,If its a 'stroker" motor you can get
alot more turbulence stirred up by the rotating crank shaft,But if its bad
at idle it should be alot worse at full rev's
Its a start..
Gav
Once your've had RAT.....
you'll never go back
67rs/454
Old Dec 28th, 09, 11:39 PM
gene
no pvc system but did take the caps off both valve covers and oil still came out of the dipstick tube when reved up but when it idles it doesnt come out of the oil tube.
Old Dec 28th, 09, 11:44 PM
gene
the oil level is on the mark on the dipstick, it only comes out when we idle the motor up. at a idle it does not come up the tube .
Old Dec 29th, 09, 12:13 AM
dnult dnult is offline
Overfull or a major blow-by issue can cause it. The top of the dipstick should have a rubber seal in it. Is the seal damaged?
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Old Dec 29th, 09, 03:13 AM
ORENCH ORENCH is offline
Bruno
Lightbulb Re: oil coming out of dipstick tube 350 2 bolt main
Is the PVC valve working properly? Also try an oil Breather/Filler Cap, like the one bellow. if this doesn't help, then you might have a blow-by situation.
"Our affair with Camaros is a life sentence without the possibility of parole".
Old Dec 29th, 09, 04:48 AM
SPARKY69's Avatar
SPARKY69 SPARKY69 is offline
BILL
Sounds like the pcv system is not working..make sure your pcv is new or cleaned out or unclogged and the same with the breather filter on the other valve cover too..make sure the pcv hose is pulling vac when the car is running!..ALSO CHECK THE VC'S, IF THEY ARE AFTERMARKET SOMEBODY MIGHT HAVE THE BAFFLE CLOSED OFF ON THE UNDERSIDE OF THE VC(ANOTHER WORDS THE VENT IS NOT OPEN OR ABLE TO PULL)
BILL D.
JOHN 3:16
SEMPER FI
if you have a bbc in your 1st gen 67-69 camaro click on the link below and enjoy the veiw and post yours up!!
http://www.camaros.net/forums/showthread.php?t=169199
if you have an all original 1st gen camaro 67-69 click on the link below and enjoy the veiw and post your up!!
http://www.camaros.net/forums/showthread.php?t=179697
Old Dec 29th, 09, 05:23 PM
77wolf10.85's Avatar
77wolf10.85 77wolf10.85 is offline
Tim
a.oil level correct?
b. dipstick may be wrong. I would drain the pan and put 5 quarts back in, check against mark on stick.
Tim Smith
  #11
Old Dec 29th, 09, 05:34 PM
arocars arocars is offline
Your engine should not be blowing oil out of the dipstick tube. That is evidence of too much crankcase pressure. Typically, this is caused by a bad head gasket (cylinder head pressure leaking into the crankcase). Rule out the simple stuff first. Remove the PCV and shake it. Can you hear the ball bearing inside? If yes, put it back in, its likely fine. Do you have a breather? If yes and it doesn't look all crungy, its also probably fine. Then, do a compression test. A compression gauge is cheap and this is something you can do in the driveway with a helper to turn the key. Look for one cylinder much lower than the rest. If so, replace both head gaskets.
  #12
Old Dec 29th, 09, 07:18 PM
gene
oil level dead on mark but it does have a aftermarket stick i will try changing the oil and see
  #13
Old Dec 29th, 09, 07:22 PM
gene
thanks guys i will try the suggestions tomorrow and will update then
  #14
Old Jun 14th, 12, 06:32 PM
whisjr08 whisjr08 is offline
Jared
I know this is an old thread, but did you ever figure out the problem, because my chevy 350 is doing the same thing?
  #15
Old Jun 14th, 12, 06:53 PM
69-Pace's Avatar
69-Pace 69-Pace is offline
Default Re: Oil coming out of dipstick tube 350
When was the last filter and oil change?
Easy to drain, and make sure its not over filled.
If it is not that try these common reasons for oil blow out
PVC is functioning? - Most common issue breather is clogged or valve is malfunctioning
Compression ok on all 8?
Rings are okay?
Guides okay?
These three seem to travel together....
Run each up to TDC and use 100 psi in the spark plug hole and listen for death rattle in heads or carb or exhaust.
1969 Z11 Pace Car - L48 350cid/300hp - 4 Speed Muncie 12 bolt rear.
Finally back on the road after being stranded in the garage for over 20 years. Follow her progress back to the road http://69pace.blogspot.com
Team Camaro Tech > All Generations > Troubleshooting      Current Topic: Oil coming out of dipstick tube 350
Location
Location
First Name
Human Verification
