can someone explain tall vs short deck BBC? - Team Camaro Tech
Thread Tools Display Modes
Old Jan 8th, 10, 10:48 AM
jostby jostby is offline
Tech Team
jeff
Question can someone explain tall vs short deck BBC?
I've been reading up on the Big Blocks but haven't found good referance to what the differance between the two are (other than deck height).
Is one a smog motor? Do the two use a differant stroke? One a farm truck block vs performance?
Thanks,
Jeff.
Old Jan 8th, 10, 01:37 PM
1969ProStreetCamaro 1969ProStreetCamaro is offline
David
Default Re: can someone explain tall vs short deck BBC?
Thanks,
Jeff.
Tall block BB's are sometimes categorized as "industrial" engines.This stems from the fact that they were mainly used in heavy duty trucks suitable for farm and/or fleet type work. Although their original intent is more "pedestrian" in nature....they can be built to performance standards. Performance parts can be obtained but header fitment and hood clearance becomes an issue when installing the tall deck in our beloved Camaros.
David F.
"All I need is a fast machine". Steve McQueen
My Machine: 1969 Pro Street Camaro
468 CID 661 Horsepower Turbo 400
33"x19.50" Mickey Thompsons
Check Out My Camaro
661 Horsepower 468
Old Jan 8th, 10, 03:44 PM
Everett#2390's Avatar
<Jake-68's rule
The easiest visual inspection of the difference between tall block and short block is to look at the water pump-to-cylinder head deck.
Short deck engines, the top of the w/pump bolt to the block is at the deck.
Tall deck blocks have the deck 3/4 inch higher than the top of the w/pump.
Old Jan 8th, 10, 04:18 PM
Vintage 68's Avatar
John
Thumbs up Re: can someone explain tall vs short deck BBC?
... what the differance between the two are (other than deck height).
... Do the two use a differant stroke?
... One a farm truck block vs performance?
Thanks,
Jeff.
As stated, they were originally a truck application to allow the use of a different piston-ring package with additional ring.
- Tall deck blocks use a special intake manifold and distributor to allow for the additional height. Other than that many parts can be the same as a standard deck.
- The 'stroke' of a standard and a 'tall-deck' 427 are the same, only difference is the piston.
- Although they are/were engineered to increase engine cycle life for industrial/HD truck applications, they are also used in some factory HP applications - like the 700HP 572 Big-blocks
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Jan 8th, 10, 05:14 PM
rodent4 rodent4 is offline
Jim
Old Jan 8th, 10, 05:22 PM
David
Thanks for the pics illustrating the different waterpump mounting locations.
David F.
www.firstgens.com
Check Out My Camaro
661 Horsepower 468
Old Jan 8th, 10, 07:21 PM
fatblock fatblock is offline
Thanks,
Jeff.
Typical oem passenger blocks circa 60,70,s measured 396/402/427/454.
The T engine(tall deck) 366/427.
All these engines shared the 3.76 stroke aside from the 4" 454 passenger.
The .400" increase in deck height with T engines allowed a 3rd compression ring to be used for heavy duty applications.
George
68 Camaro
8-71 blown 461 Rat on E-85
Old Jan 9th, 10, 03:25 PM
77wolf10.85's Avatar
77wolf10.85 77wolf10.85 is offline
Tim
I had a TD427 irrigation engine block. It had OEM gear driven cam, block was drilled for thrustwasher plate retention. That would be a quick way to spot one if you were just eyeballing bare blocks.
The 366 had main cap side tie bolts iirc. 427TD didn't.
Tim Smith
Old Jan 9th, 10, 06:35 PM
Vintage 68's Avatar
John
Wink Re: can someone explain tall vs short deck BBC?
If it had the gear drive and the trust plate then it was a Counter-Rotation unit
Very common set-up for them as well as Marine units.
1968 Convertible
Some trucks
Old Jan 9th, 10, 07:54 PM
RichSchmidt RichSchmidt is offline
Rich
A quich visual on the difference,The standard deck is flush with the top of the water pump.With a tall deck the distance between the top of the water pump and the deck will be about the same as the thickness of a 3/8" bolt.
With modern "3D" profiled steel connecting rods,you can probably squeeze a 4.5" stroke crank into a 427 tall deck truck block.The tall deck 427 isnt notoriously thick like some earlier engines,so it isnt a given that it will bore out to .125" over,but if you did bore that much,you could have a really big engine based on a cheap truck block.I use 3D rods in a regular 454 block with a 4.25" crank and have tons of room,so with minimal grinding I could see another 1/4 inch of stroke going in.If you tried to get a 4.5" crank in a low deck,the rods might not hit,but the pistons would have to be too short to actually work,thats were the tall deck steps in.
On a lighter note,I have seen some of the "inner city" type racers use them "4 ring boat anchor" 366 truck engines with multiple kits of nitrous to make crazy power with junkyard parts.I have seen these guys take a school bus engine out of the junkyard,put an aluminum ravcngi ntake and 3 nitrous plates on it,cram it into a gutted out Malibu or Cutlass or whatever and make a lot of money off of unsuspecting victims,and the engines last forever.
  #11
Old Jan 10th, 10, 06:35 PM
Tech Team
jeff
Thanks guys, all excellent answers with interesting tidbits of info
I shall wonder no more!!
Jeff.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: can someone explain tall vs short deck BBC?
Location
Location
First Name
Human Verification
