whats your recommended or favorite cam break in lube??? whats your recommended or fav - Team Camaro Tech
Old Apr 11th, 03, 10:40 AM
cody cody is offline
Post
I am about to get my BBC Solid Ultradyne 288/296 cam. I am using some dual valve springs that AFR is putting on my heads, don't know exact specs but they are for a "solid cam". I AM using GM's E.O.S, but am wondering what you guys suggest for Cam Lube, i have heard conflicting things. what brand or part numbers do you guys like? Also i am going to try to get the motor fired as quicly as possible and not take out the inner springs, if it doens't crank right away, then i will pull the inner springs. i was going to use comp's stuff, but everyone here thought their stuff ain't so great
here are my spring specs
395 open at peak lift
145 seat pressure
with a 610 lift cam. thanks.
71 formula firebird, 468; AFR rectangle port, 11-1 compression, Isky Solid Roller 290/294,...620HP, Viper T56 six speed, 19" CCW rims, Hydroboost, C5 corvette brakes.. currently being built(almost done)http://www.formula454.com
Old Apr 11th, 03, 02:02 PM
1 2RUN 1 2RUN is offline
Post
I use Crane's black moly lube. 99002-1
'69 RS Camaro 355 5-speed 4.11
Old Apr 12th, 03, 12:55 AM
Toby Keen Toby Keen is offline
Post
I like to use the cam manufacturer's recommendations for both break-in lube and valve springs. It might save some grief down the road.
Old Apr 12th, 03, 08:18 AM
JohnZ JohnZ is offline
Team Member
John
Post
I'd check first with Ultradyne and see what their spring recommendation is, and not just use the "solid lifter springs" AFR is putting on your heads without knowing what they are, what the installed heights are, how close they are to coil bind at your cam lift, etc. I would NOT fire it and break it in with 400# dual springs installed.
JohnZ
CRG
'69 Z/28 Fathom Green
Old Apr 12th, 03, 09:57 AM
BillK BillK is offline
Post
Cody,
You had better check with Harold at Ultradyne about those springs. Most flat tappet cams will not survive with much more than 340-350 lbs open pressure.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
1971 Chevelle "Heavy Chevy" original owner
Enginerepairshop.com
Old Apr 12th, 03, 11:43 AM
Post
They said they were 350 open seat, but when he did some calculations?? he said with a 610 lift cam, they come out to be 395? whatever that's all about i don't know, I will be giving them a call on monday to ask. thanks
Old Apr 12th, 03, 12:23 PM
BillsCamino BillsCamino is offline
Bill
Post
Really any moly lube is fine but definately use the GM EOS. Even some cam manufacturers recommend it.
'72 Chevelle Concours Wagon
Cruiser 5.7L TPI, 200R4, 3.55 12 bolt Posi
Team Chevelle #613
ACES #3920
Old Apr 14th, 03, 07:13 AM
Milan Milan is offline
Post
Cody I urge you to remove the inner springs. I am re doing my entire bottom end now as a result of a cam failure. I would not take that chance again!
67 Blown Alcohol Camaro "The Combat Rat" 8-71 and E-85/71 BB SS Chevelle "cheap street" (clone) 12.871 @ 107.59 w/1.915 60' and spinning /2002 35th anniv SS Z28 conv./74 454 El Camino .
