Anybody run a mini spool on the street? - Team Camaro Tech
Old Jan 20th, 10, 06:08 PM
OK69 OK69 is offline
Joe
Default Anybody run a mini spool on the street?
I just wonder if it works ok. Summit and places like that say not to do it.
Old Jan 21st, 10, 03:53 AM
SPARKY69's Avatar
SPARKY69 SPARKY69 is offline
BILL
Default Re: Anybody run a mini spool on the street?
Its kinda old school, not really the best thing for a car on the street..i had a 80 malibu that was all hot rodded up with a mini and a 410 rear .. It was fun but it wasnt an everyday driver!
BILL D.
JOHN 3:16
SEMPER FI
if you have a bbc in your 1st gen 67-69 camaro click on the link below and enjoy the veiw and post yours up!!
http://www.camaros.net/forums/showthread.php?t=169199
if you have an all original 1st gen camaro 67-69 click on the link below and enjoy the veiw and post your up!!
http://www.camaros.net/forums/showthread.php?t=179697
Old Jan 21st, 10, 04:53 AM
big gear head big gear head is offline
Freddie
A mini spool or any spool is dangerous on the street. They put a lot of stress on axles, studs and wheels and can cause them to break. I have seen axles, studs and wheels broke from using a spool on the street. The people that I know where lucky and nobody got hurt when it happened.
'69 RS/SS396 pro street/427/4spd/9"
http://www.camaros.net/showroom/show...00&ppuser=1922
Old Jan 21st, 10, 11:05 AM
Moonpie Moonpie is offline
Mickey
When you turn corners a spool makes both axles turn at the same rate so you get a lot of wheel hop, skidding,etc. which is where the danger and damage come from. They're cool for racing because obviously you only go straight line. If I had a car that rarely saw street action then I would be tempted to go with a spool.
Old Jan 21st, 10, 11:49 AM
Steve69SS396's Avatar
Steve69SS396 Steve69SS396 is offline
Steve
I ran a mini spool in my '67 Mustang for several years in the '80s without any issues. The car had a Ford 9" with factory 28 spline axles and wheel studs.
I've been running a spool in my Camaro for the last 10 years. It has a Ford 9" with 33 spline Moser axles and 7/16" Moroso wheel studs. Again, no breakage. I've run regular radial tires, drag radials, MT ET Streets and Hoosier QT Pro's.
The only time I notice the spool is when making a slow tight turn. You do go through tires much quicker if you drive it very much. My car has no sway bars and is setup for drag racing. I would not use one in a car that you expect to drive fast on winding roads. And let me clarify this last point. I have no problem keeping up with traffic through corners but if you expect to run considerably faster than the speed limit through a corner you will more than likely be in trouble.
That's just my experience.
'69 Camaro - 427 SBC Dart Iron Eagle 9.325" block, Cola crank, Lunati 6" Pro Mod rods, JE pistons (13.8:1), Total Seal rings, hand ported AFR 210 heads, Jesel belt drive, custom ground 4-7 swap solid roller 274/286 @ .050" with .660" lift, Dart single plane, 1050 Dominator, Stef's #1705R oil pan, NOS big shot, Lemons 2" primary 3-1/2" collector, Coan 8" converter
Old Jan 21st, 10, 02:48 PM
CrashBox CrashBox is offline
Tech Team
Russel
I had one in a 79 mustang that drove on the street everyday. The car was gutted to a shell and was very light. I ran low 12s high 11s and drove everywhere. Turning the car was smooth you never knew the mini spool was back there. Years later I sold the car and they put that 9 inch rear end and my motor in a full interior show car. After that you couldnt even stand to drive it on the street, it jumped and banged around corners so bad from the extra weight. Also you run the risk of breaking the pin that ties it to the carrier.
Old Jan 21st, 10, 06:36 PM
z28kid z28kid is offline
TJ
i dont recommend using the powertrax locker, i wish i would have spent more and got the detroit trutrac. the more miles you put on the powetrax the louder and more "snappy" it gets.
Old Jan 27th, 10, 09:16 PM
ChrisM ChrisM is offline
Tech Team
I have a Eaton limited slip unit from Rick's in my 68. It came with huge springs and really locks up both wheels. If they didn't say it was limited slip, I'd think it was a true posi. Does anyone else have experience with this Eaton unit?
Old Jan 27th, 10, 09:49 PM
Eleanor's Nemesis Eleanor's Nemesis is offline
Michael Gekko
I ran a mini spool for a while in a camaro, 12 bolt with moser axles and 4.10 gears...never had any problems. I used BFG radial T/As on the street, it is a harder tire that wonuldn't grab as hard on the street as my Hoosier QTP's .
I never drove it in the rain though, I think that would be inviting some problems.
If you are really concerned you might want to look into a detroit locker. A friend of mine a long time ago put one in his 64 comet....we had always heard they would pop and bang and chatter and stuff when making tight turns, his didn't do that at all.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico
1968 Street/Strip Camaro 350 w/PG
1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP
Land of the Free Because of the Brave
It Takes a Long Time to Grow Old Friends
