Bypass horn relay & voltage regulator - Team Camaro Tech
Thread Tools Display Modes
Old Feb 9th, 10, 06:57 PM
camaro434 camaro434 is offline
Default Bypass an external voltage regulator
How do you bypass an external voltage regulator when installing a new alternator? Wiring diagrams would help.
Old Feb 9th, 10, 08:09 PM
DOUG G DOUG G is offline
Default Re: Bypass an external voltage regulator
Here's some reading.... http://www.camaros.net/techref/ftecref14.html
68 Camaro~LSx
Best to Date....and tuning
1.546 60'
7.132 @ 94.43 660'
11.327 @ 116.79.
RedЯum <-Pics
https://youtu.be/Of8WVNYhR1g <~More here
Old Feb 9th, 10, 08:28 PM
jr68's Avatar
jr68 jr68 is offline
Team Member
Jerry R.
hey Doug thats the diagram I used to convert mine, worked great.
my Magnaflow X-pipe system sound clip, click the link
http://s258.photobucket.com/albums/h...naflowclip.mp4
Old Feb 10th, 10, 05:49 AM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Some of the after market suppliers such as Ricks offer a small, inexpensive harness for quickly modifying the existing wiring harness for internal regulated systems. They're a few bucks... plug & play. I don't know if anyone has used one or how convenient they are, but I have one that I haven't installed yet.
Check it out.
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Feb 14th, 10, 04:04 PM
Default Bypass horn relay & voltage regulator
I am going to explain this the best I can. I want to bypass the voltage regulator because I went with a new alternator with internal voltage regulator. Next I want to bypass the horn relay because it is totally rusted inside. My car won't start with all the wires disconnected. So what wires need to be connected together for the car to start?
Old Feb 14th, 10, 04:32 PM
Everett#2390's Avatar
<Jake-68's rule
Default Re: Bypass horn relay & voltage regulator
Mad Electric has the method of bypassing the ext regulator.
The two red wires screwed together by the screw on the horn relay buss bar will transfer power to the rest of the car.
Old Feb 14th, 10, 06:51 PM
They don't have wiring diagrams to bypass the voltage regulator.
Old Feb 14th, 10, 06:53 PM
Originally Posted by DOUG G View Post
This is wrong, My wiring doesn't look like there diagrams. I tried this it does not work.
Old Feb 14th, 10, 07:52 PM
DjD's Avatar
DjD DjD is offline
Dennis
Take a look in our Tech Reference area above on the red tab bar... Here's a direct link to a 1 wire conversion, don't know if it covers your alt but have a look...
...Dennis
www.camaroslimited.com
Old Feb 14th, 10, 08:07 PM
I tried this but it does not work. This info is not right either.
  #11
Old Feb 14th, 10, 08:45 PM
jr68's Avatar
Team Member
Jerry R.
It's what I used and works great
  #12
Old Feb 15th, 10, 04:01 AM
<Jake-68's rule
Do you still have the original harness?
If you do, at the ext regulator connector, jumper the two outside wires together.
Follow along here:
http://www.madelectrical.com/electri...evymain1.shtml
  #13
Old Feb 15th, 10, 04:26 AM
<Jake-68's rule
What does your wiring look like?
  #14
Old Feb 15th, 10, 06:36 AM
From this link: http://www.camaros.net/techref/ftecref14.html The white wire & the orange (which is red) does not get capped off. They jumper together. This person does not know what they are doing.
  #15
Old Feb 15th, 10, 08:08 AM
DjD's Avatar
DjD DjD is offline
Dennis
Greg that tech info has been tried and true by many! If it doesn't work for your situation it doesn't mean the info is bad...
...Dennis
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Electrical & Wiring      Current Topic: Bypass horn relay & voltage regulator
Location
Location
First Name
Human Verification
