Recommended rear end gear ratio for TKO 600 - Team Camaro Tech
Old Feb 22nd, 10, 01:16 PM
johnv805 johnv805 is offline
Tech Team
Default Recommended rear end gear ratio for TKO 600
I have a camaro with a 327 ci 300 hp engine, 3.55 posi rear end, and a TKO 600 (.64). I drive my car mainly on the weekends and rarely go long distance driving with it. I want more acceleration so I am thinking of upgrading to a 3.73 gear ratio. Is that ideal or should I go higher.
Old Feb 22nd, 10, 01:29 PM
Eric Kammerer Eric Kammerer is offline
Default Re: Recommended rear end gear ratio for TKO 600
What size rear tire do you run?
Just based on your 1st ratio and rear ratio now, you are over 10:1 multiplication, which is pretty optimal for a street car.
http://www.chevyhiperformance.com/te...ing/index.html
With a 327/300, I am going to go out on a limb and suggest that the rear axle ratio is not the most limiting factor on off the line acceleration.
Eric
69 'vert project big block/TKO 600 RR
68 'vert driver RS clone -- gone!
Old Feb 22nd, 10, 01:32 PM
rojo rojo is offline
Robert
I doubt you would notice the difference, it's only 5%. The 3.55 or 3.73 is a great choice with the 2.87 TKO600 first gear. I'd spend my money on the engine.
Robert
'69 355ci 10:1, 64cc Edelbrocks, Comp Mag 280H, Performer RPM, 700r4 (2000 stall), 3.55 posi A/C PS PDB Hotchkis
'67 369ci 10.3:1, 64cc Edelbrocks, Voodoo 276/284, Performer RPM, Holley 650DP ...4spd 3.73 Moser 12 bolt
'77 Dodge Powerwagon 340ci X-head 727 NP203 Dana 44 / Mopar 9.25
TC member #18
Old Feb 22nd, 10, 02:29 PM
Tech Team
I'm currently running 225/60R15 and maybe considering changing to 275/60R15. If the 3.55 is a great choice then I might just spend money on the engine.
Old Feb 22nd, 10, 04:54 PM
idoxlr8 idoxlr8 is offline
Tony
With the 255's I would stay with the 3.55 gears, Even with the 275's your gears and the 1st gear of the 600 are enough to roast the tires at will. Traction is the limiting factor.
Tony:
67 RS Clone, 388 SBC/Keisler TKO 600/12 bolt, 3.90 gear w/posi and a 250 shot of N2O for fun. See my progress at: password is camaro
http://smg.photobucket.com/albums/v108/idoxlr8/
Old Feb 23rd, 10, 02:58 PM
68RS-SS 68RS-SS is offline
Bill
I've currently got the TKO600 .64 OD and 3.73s. It's truly a nice combo but in my opinion what you have is slightly more ideal. There's times when I'd like a tad more out of my gears. I have a 12-bolt with series 4 carrier so can't go down any more otherwise I'd be happy to trade. My wheels are 17" and probably a little taller then what you currently have or similar to what you're planning on. I'd leave it alone and enjoy it.
Old Feb 24th, 10, 03:43 AM
SIDEWAYS SIDEWAYS is offline
With a 327 and a .64 od, and the fact that you rarley go on long distances, you would be MUCH better off with the .82 OD unit and a 3.55-4.11 rear. You will never end up being able to use 5th gear. I have a 509, TKO600 .64, and 3.90's...and 5th is still too tall for what I do, unless I'm on the highway. Will likely end up with a TKO w/.82 OD and change the gear to 3.55.
VINCE
69 CHEVELLE SS
502 EFI/[224/228 HR]/T56/3.90
*1.8/11.59/124.34*
Old Feb 24th, 10, 06:59 PM
Steiner Steiner is offline
Steiner
If you go to a 275/60 your acceleration is only going to get worse. The tire is going to get taller which is the same as going to a numerically lower gear, almost like going to a 3.23. The calculator says if you put a 275/60 on you would need to go to a 3.73 just to get back to where you are now.
I think a 4.11 would put you where you want to be with your current tire size given that you rarely do any highway driving. Gears are probably the cheapest thing at this point unless you want to spend the money on engine work. If you're thinking about gears you ought to spend $50 to do a dyno run to find out where your power band is than set your gears up to be fun where you do 95% of your driving.
Play with the calculator:
http://www.keislerauto.com/speed_analyzers.php?sa=gm_5
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
Old Feb 24th, 10, 08:06 PM
Vegas69 Vegas69 is offline
Todd
How is that going to help his acceleration problem? I disagree with you. In anything other than a race enviroment, the .64 gear is perfect for crusing at 80 around 2500 rpm with a 3.73. One of my favorites when I'm not racing.
I do agree that a little lower rear gear would help that little engine. I don't think swapping from a 3.55 to 3.73 is going to make you happy though. More power is what you need.
Old Feb 25th, 10, 05:24 AM
Vince, keep in touch if you decide to change to the TKO600RR (0.82 OD). That is what I bought because that was what was available in 2004, and my mild 402 seems like it might like the 0.64 5th. I don't know when/if I will be recovered enough from my accident to be able to swap trannys, but if you wanted to change to the 600RR, maybe we could work something out.
I am just out west in Downingtown, so you can't be too far from me.
Eric
Old Feb 26th, 10, 03:24 AM
As far as acelerating, and given he want maybe a 275/60/15 tire, I think a 4.11 is what I would go with, maybe even deeper being its a 327. But the fact that he RARELY see's the highway, I just think the .82 is a better choice, b/c now you have a 5th gear that you can use around town and on the back roads. The .64 is apprx a 1000 rpm drop from 4th to 5th, and not all motors will like that AROUND TOWN. Right now, my motor screams in 4th, but lugs in 5th. On the highway...different story, you can run whatever gear you like. Depends on what your intentions are.
I ran my TKO 600 .64 with a 3.31 rear and couldnt use 5th unless I was doing 65 min, and it really liked 75. I have 3.90's now, and still cant really use 5th around town/backroads - my primary type of driving. Highway - feels like I could use 3.42 or even higher though.
He may have the trans already, so its a mute point. I wish they would make an OD trans with a .7x OD ratio. But keep in mind, a 4.11 gear becomes a 3.37 with the .82 OD, and 2.63 with the .64. You really need to know how your motor runs at various rpms before making decisions about transes and rear gears IMO.
VINCE
69 CHEVELLE SS
*1.8/11.59/124.34*
Old Feb 26th, 10, 04:59 AM
68Lemans blue 68Lemans blue is offline
Jerome
.64 and 3.73's with 225/60-15 nice and happy here...... Happy motoring
Old Feb 26th, 10, 07:34 AM
Tech Team
I drive my car to work about once a week which is a 12 mile commute and when I use it on the weekends the longest I will drive it will be 15 miles. I never race my car on the tracks. I don't want my 1st gear to run out quick. Here are my engine specs.
327 ci 210hp
Edelbrock Head Gaskets (Compressed Thickness 0.038 in.)
Flat top pistons
Compression Ratio 8.75:1
Bored out 0.02 over
Pertronix Ignitor II Electronic Ignition
Flame Thrower II Coil
MSD-6AL Ignition Control Box
Edelbrock Performer Air-Gap 2601 Intake Manifold
Edelbrock Thunder Series 1806 Carburetor (650 CFM)
Edelbrock Performer 60759 Aluminum Cylinder Heads (70cc Chamber, 185cc Intake Runner, 2.02 Intake, 1.6 Exhaust)
Edelbrock Performer-Plus Hydraulic Roller 2208 Camshaft (Duration 280/290, Lift .462/.479)
Full Length 4-into-1 Hedman Hedders
Flowmaster Dual Exhaust with 40 Series Delta Flow Mufflers
Old Feb 26th, 10, 08:55 PM
TMessick TMessick is offline
T
IF you decide to change your rear gears, I'd go to 4.10's -- I don't think the change from 3.55 to 3.73 will be significant enough for you to really feel it much.
As far as the comments about the usability of the 0.64 5th gear, I guess I'm special since I found 5th usable behind my 307 even with 2.73 rear gears. It wasn't exactly a rocket ship in 5th, but would run down the road OK at 55mph. Of course my engine was mildly cam'd and carb'd and ran a lot of spark down low to keep things running smooooth. If your engine doesn't like low RPM, you can end up with issues with the wider 4/5 spacing... (Finally changed over to 3.73's now, but am still working through re-bleeding the brakes and getting it back on the road).
From your above description, I think I'd spend some $ on cylinder heads 1st. With the 70cc chambers and 8.75 compression, you're losing some torque and efficiency. Cam is a bit mild (212/222 at 0.050" if I'm reading the specs right) and probably won't like to rev too high, but should play decent on a street motor. Maybe go a step bigger if you're OK losing some bottom end to pick up higher RPM power...
Old Feb 26th, 10, 11:13 PM
Tech Team
What cylinder heads and cam would you recommend?
