Cam upgrade for ZZ383.... need input - Team Camaro Tech
Thread Tools Display Modes
Old Mar 5th, 10, 07:36 PM
Fred Mertz Fred Mertz is offline
Dave
Default Cam upgrade for ZZ383.... need input
It's been 3 years now since installing a GMPP ZZ383 in my '69. I'm thinking about changing the cam to get rougher idle. The stock cam pulls a very steady 18 inches of vac, at idle. I'm looking for suggestions for a cam that would not lose me low end torque but get the idle I'm looking for.
I topped off this crate motor with the following parts:
Edelbrock Air-Gap vortec intake
MSD 8360 Distributor
Holley 650cfm vac, sec. carb #80783-1 (also have similar 750)
D368 headers
M22W 2.54 first gear
ProComp 1.6 roller tip rockers(still have 1.5 GM rollers)
Dave
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:42.
Old Mar 5th, 10, 08:04 PM
Mike's67 Mike's67 is offline
Default Re: Cam upgrade for ZZ383.... need input
Hey Fred, If you ever heard my car(red 67 camaro) at any of the vacaville shows, it has a zz4. I used a xr276hr quite a bit lumpier than the 268.
67RS-zz4 w/ trickflow heads 276hr cam air gap 780 Pro Systems TexRacing 4spd AGR steering SCAT procars 12 bolt eaton posi 3.73's SSBC all around, TT2's Dakota Digital Painless DSE hinges
http://i231.photobucket.com/albums/e...e/DSC_0104.jpg
Old Mar 5th, 10, 08:07 PM
Steiner Steiner is offline
Steiner
When I had my 383 originally quoted (which has since grown into a Dart 400 thanks to my tax refund), my builder selected the cam with me after going round and round on what I wanted. 100% street driven and wanted gobs of midrange since I'm running a 3.42 and five speed OD trans.
He came up with the Comp Cams XR276HR (hydraulic roller) but ground with 224/224 on 108 lsa (normally it's 224/230 on 110 lsa) along with 1.6 rockers to get the lift up some. If you're running Vortec heads you might want to keep the extra exhaust duration. Mine was going to have AFR-195's. He said that would give me what I wanted and still pull around 14" at idle and we were going to keep compression ratio around 10:1.
'69 Camaro
Dart 400-AFR 195-224/224 HR-Powerjection III TB with F.A.S.T. Sportsman XFI
TKO 600-Moser 3.42-Detroit Truetrac
500hp/538lbft
www.cmengines.com
'69 Camaro Beater-SFT 327-M20-Moser 4.10-sold
'02 Z/28 vert-stock-sold and totaled
Old Mar 5th, 10, 08:11 PM
Eleanor's Nemesis Eleanor's Nemesis is offline
Michael Gekko
Whenever you start increasing duration to get a rougher idle it is very likely low RPM torque is going to suffer a bit. You could circumvent that compromise by utilizing a looser torque converter, or in your case slipping the clutch a little more or even going to a different clutch set up, and using a lower gear.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico
1968 Street/Strip Camaro 350 w/PG
1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP
Land of the Free Because of the Brave
It Takes a Long Time to Grow Old Friends
Team Camaro Tech > All Generations > Performance      Current Topic: Cam upgrade for ZZ383.... need input
Location
Location
First Name
Human Verification
