Not happy with 255-60-15 15x8 rally - Team Camaro Tech
Wheels & Tires What fits what?
Thread Tools Display Modes
Old Mar 6th, 10, 12:55 PM
c6matt c6matt is offline
Default Not happy with 255-60-15 15x8 rally
I just bolted on my new rear setup and it looks terrible (IMO) the wheels/tires stick out way too far. (rear is 15x8 vette with 255-60-15 BFG)
I am thinking of going to a 15x7 in the rear. what is the stock backspacing?
I have 215's i the front was thinking of 225 or 235 in the rear. Will the back spacing and 15x7 rim pull a little of the "joe dirt" look out? I'm just worried that the 235's will still have a little of the look to them that I currently have, but will the stock BS and 7" rim might fix that.
67 Camaro LS1+ tvs2300/4L70E 530 RWHP
64 Corvette Coupe 350/ TKO600
66 Mustang (289/C4)
Old Mar 6th, 10, 01:50 PM
Melrose RS Melrose RS is offline
Tom
Default Re: Not happy with 255-60-15 15x8 rally
Matt, 235/60-15 is what I was running all around on 15x7 ralleys. They will definitely not stick out as far on the rear as the 15x8 255. But I wouldn't go any smaller than 235/60 on the rear as they would look too short in my opinion.
I went up to 15x8 on the rear with 235 to get the tires a little closer to the wheel well lip. If I can find a photo, i'll post it up.
'67 rs - ordered new by my Grandfather
327 L30, K-K, Deluxe int, tach & gauges, 12 bolt posi, 4 speed.
the Melrose rs - L30 327/275hp
Old Mar 6th, 10, 02:06 PM
muzzy muzzy is offline
Murray
Yep I had that problem with AZ coded Corvette 8" rims,they have 4" back spacing as opposed to the 4.25 back spacing of the standard 7" rim.
It becomes a bigger issue if the car is lowered the tires will rub badly.
I personally couldn't handle the look of the rear wheels sticking out like that or the tire contact with wheel arch so changed rims.
Old Mar 6th, 10, 03:04 PM
A pic of your car would be great! what BS did you use on the 15x7?
66 Mustang (289/C4)
Old Mar 6th, 10, 03:15 PM
rlyfst1 rlyfst1 is offline
Lane
I'm running 235/60-15 on 15X7 ralleys in the rear and very pleased with the look.
Old Mar 6th, 10, 03:19 PM
Camaros-n-Chevelles's Avatar
Camaros-n-Chevelles Camaros-n-Chevelles is offline
Hi Matt,
Here is my 68 with 255-60-15s on the back and 235-60-15s on the front. The rims are 15x7. You are correct, the 15x8 Rally Rims push the rear tires too far out. I did not like the look with the Rally Rims either and changed to the Torq Thrusts. To change the look of my Camaro, I have a set of 245-60-14s mounted on the original 14x7 Rally Rims.
Tory
1968 Camaro Coupe
1964 Malibu SS Unrestored 36,000 Mile Survivor
1964 Malibu SS Hardtop
1966 Chevelle SS 396
1968 Malibu L-79, 1 of 4082 ~ SOLD
1955 Chevrolet Bel Air Unrestored 15,000 Mile Survivor
1955 Chevrolet Nomad
1984 Hurst Olds with Factory Sunroof, 1 of 99 ~ SOLD
1992 Camaro 396 LS, 4L60, 9" Posi w /3.50:1 Gear Set
Old Mar 6th, 10, 03:40 PM
Joe Harrison's Avatar
Joe Harrison Joe Harrison is offline
67 Camaros Rock
15X8 4.0 back space Rally with a 232/60/15 BFG In the other shot they are also on the front, I had rub at full right or left turn and a very lite rub strait at the wheel well on big bumps or dips in the road. Lowered in front with hotchkiss springs. To be honest I thought they would have rubbed alot more and everyplace. These were on as an experiment. The rear could have swallowed a 255 with out issue
These are 15x7 with 235/60/15 on 15x7 with 3.78 back space. Front is coil overs rear stock but empty trunk and lots of other parts missing as you can see. Hope this helps a little. It needs a 25560/15 in the rear. I would like to go bigger if possible and may order my torque thrusts from http://www.etwheels.com/et/classic5.html# I can get a 15x8 with 4.5 inch back space.
"If you can leave black marks on a straight from the time you exit a corner till the time you brake for the next turn.......
Then, you have enough horsepower."
-Mark Donahue
My 67 Camaro Time Line http://www.camaros.net/forums/showthread.php?t=211805
Old Mar 6th, 10, 04:25 PM
Tom
These are 235 60-15 on the rear on AZ 15x8 with 4.0 bs.
and 235 60-15 on the front on 15x7 with 4.25 bs.
Old Mar 6th, 10, 09:03 PM
rad454's Avatar
rad454 rad454 is offline
Louie
Lane, nice looking car. what are you running up front?
69 SS/RS Fathom Green 454 4 speed
Bumper sticker- My other auto is a .45
Old Mar 7th, 10, 05:29 AM
Thanks for all the responses. Some good looking cars here!
So what is the stock backspacing for a stock 15x7 rally wheel?
66 Mustang (289/C4)
  #11
Old Mar 7th, 10, 05:54 PM
KELVINATOR KELVINATOR is offline
GEARHEAD
Tom,
Did the 8" rim make the tire look noticeably wider?
Kelvin
1969 RS Z/28
  #12
Old Mar 7th, 10, 06:09 PM
Lane
Thanks Louie, I've got P215/65R15 up front. Basically the same profile as a P225/60, but Goodrich doesn't make those with white lettering.
  #13
Old Mar 8th, 10, 08:48 AM
Tom
Originally Posted by KELVINATOR View Post
Tom,
Yes, it did. I can get a measurement for you later.
  #14
Old Mar 8th, 10, 10:10 AM
GEARHEAD
Thanks Tom! Appreciate it.
Kelvin
1969 RS Z/28
  #15
Old Mar 8th, 10, 12:49 PM
pmmcgrath3 pmmcgrath3 is offline
Tech Team
Patrick
I had 235-60-15 on the front of my 68, had to be careful if the front of the car is a little low it rubs with a 3.75 BS. We had 245-60-15 on the back with what I thought was a good look. This was with a AR Torque Thrust 15x7. Patrick
[IMG]file:///C:/Users/Patrick/AppData/Local/Temp/moz-screenshot-1.png[/IMG]
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Wheels & Tires      Current Topic: Not happy with 255-60-15 15x8 rally
Location
Location
First Name
Human Verification
