Spark plug socket - Team Camaro Tech
Old Mar 12th, 10, 11:15 AM
chidester chidester is offline
Tech Team
andrew
Default Spark plug socket
Hey guys, another question. I'm having some problems changing my spark plugs (1968 350ss). This is a new car to me and the first time I've changed the plugs on it. The engine has an old set of hooker competition headers, and I've been able to remove all of the plugs pretty easily except for one. I'd really not remove or loosen the headers as it seems like they are sealed pretty well, and it also looks like I would run into some clearance problems even trying to remove the headers with the engine in the car.
My question is have you all ever used these "header sockets"? I found a website selling these. It looks like it may work. Anyone used these, or have any other suggestions? I included the link to the website.
Thanks.
http://www.autotoolworld.com/HeaderS...s_p_47794.html
Old Mar 12th, 10, 11:21 AM
68RS-SS 68RS-SS is offline
Bill
Default Re: spark plug socket
Was wanting to try those out myself but they are a little pricey. I've found that what has worked well enough for me is using a basic plug socket and then a 12pt. wrench to turn it vs. the wratchet. This method has really helped with the couple of difficult plugs.
KMG69 KMG69 is offline
Ken
Instead of using a ratchet, use the spark plug socket and then use a 3/4" wrench on the end of the socket. Been doing this for years and have never had to buy special header sockets.
Ken
1969 Camaro
Old Mar 12th, 10, 11:27 AM
Ken
What Bill said! lol
1969 Camaro
Old Mar 12th, 10, 11:28 AM
TJS69 TJS69 is offline
Tom
Smile Re: spark plug socket
A couple of the plugs are easier to remove from under the car, with an open-end wrench.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Mar 12th, 10, 11:32 AM
Vintage 68's Avatar
John
Thumbs up Re: spark plug socket
Originally Posted by KMG69 View Post
What Bill said! lol
X2
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Mar 12th, 10, 11:33 AM
Z15CAM Z15CAM is offline
Ron
X2 - NEVER use a Ratchet ;o)
Z15CAM - There was a Viper in my Rear View
This is my 701/2 z28
http://www.flickr.com/photos/28082975@N04
Old Mar 12th, 10, 11:43 AM
Tech Team
andrew
I would have tried that, but there is not enough room to get the socket over the plug. I only need maybe a half inch more of clearance to get my regular socket over the plug, which is why I thought the shorter socket may work.
Old Mar 12th, 10, 11:52 AM
Vintage 68's Avatar
John
Wink Re: spark plug socket
Snap-On and others sell a 'short' spark plug socket ( same idea as the specialty units pictured) for just these issues.
I use mine quite often in Marine applications where the 'wet-manifolds' are very close and restrict plug access.
Working from underneath is often the only access to some applications ...
1968 Convertible
Some trucks
Old Mar 12th, 10, 11:54 AM
Ken
Ok, then use a bent box end wrench to get it over the plug. Or slightly curved box wrench, whatever the term. Have a nice weekend and good luck!
Ken
1969 Camaro
Old Mar 12th, 10, 12:10 PM
Tech Team
andrew
Thanks for the help guys. I'll give the box end a try.
Old Mar 12th, 10, 12:22 PM
Fred Ficarra Fred Ficarra is offline
Fred
Default Re: Spark plug socket
Ya know, I solved that problem by getting rid of the Comps. Hate 'em. Too many years changing plugs the right way. Jacking up the car doesn't set well with me.
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's spool, ducted hood, Endura, spoilers.
TH400 (CX) GV OD, 8 track still on console and best et 10.862, 124.24mph 1.478 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
Old Mar 12th, 10, 12:29 PM
victimizati0n victimizati0n is offline
Ken
this is what i do, but i really think it depends on what headers you have, sometimes i cant even get the socket on and have to use a wrench or contort my arm around to get it on the plug and have no room to fit the wrench on
Old Mar 12th, 10, 01:49 PM
jimbo68 jimbo68 is offline
Jim
I have a 68 Camaro with Hooker Super Comps. All plugs can be changed from the top using a plug socket or open end 13/16 wrench.
You should be able to change the passenger side bank with the plug socket easily. On the drivers side bank only the #3 plug requires the socket side of the open end wrench to loosen up.
Otherwise 1, 5 & 7 plugs can all be reached with the socket and wrench combo. My plug socket came from Sears (craftsman) and has a 13/16 end on that works perfect.
I can change out my plugs in 10 minutes and that is also gaping them in the process. Never had to get under the car to touch any plugs! Now these are super comps and not comps, but they should be close enough. Patients helps too!
Old Mar 13th, 10, 12:07 PM
mike's blue67 mike's blue67 is offline
Mike
Thanks.
I use them they work great, never found anything easier
67 R/S Blue 406 518HP and 504TQ Dart block,Callies crank,Mahle pistons,Ultradyne cam 230/238 duration @.050 530 lift at 113 lsa, Afr 195 heads,Holley 4150HP carb and RPM Air gap. TKO600 with 373 gears
