identification/ VIN - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Mar 14th, 10, 02:12 PM
greyGhost greyGhost is offline
Tech Team
Bill
Default identification/ VIN
On the VIN of a 67 Camaro I am looking at - is there a way to determine if it is a true RS? What should the VIN say leter wise if it is a true RS?
Old Mar 14th, 10, 02:54 PM
zz3vette zz3vette is offline
Bill
Default Re: identification/ VIN
The vin tag won't tell you but the trim tag on the firewall will.
Old Mar 14th, 10, 02:55 PM
Indy 69 Indy 69 is offline
Bill the VIN plate will only tell you if it is a V8/6cyl, coupe or convertible. The Trim/Cowl tag has the info. you are looking for on a 67. Post the details here and someone will sort it out for you.
Old Mar 14th, 10, 04:04 PM
Tech Team
Bill
I have the vin # but I will have to go back and look at the car first part of the week and check out the cowl tag. Did not realize there is a difference in the two. Thanks , will post when I get the info.
Old Apr 8th, 10, 06:34 AM
Nasty 67 Nasty 67 is offline
Kevin
Bill, the 67 rs will have 3L on the cowl tag. It is down near the bottom under the interior code.
