Saginaw 4 Speed Cluster Gear Help - Team Camaro Tech
Thread Tools Display Modes
Old Apr 3rd, 10, 12:47 PM
proudpax2 proudpax2 is offline
Joel
Default Saginaw 4 Speed Cluster Gear Help
I am trying to rebuild my 4 speed, and had to buy a new cluster gear. There is a piece at the end of the original cluster gear that is not on the new one, and it appears I cannot move it from the old one (left) to the new one (right). Can anyone help!
Click image for larger version
ID:	15113   Click image for larger version
Old Apr 3rd, 10, 03:17 PM
big gear head big gear head is offline
Freddie
Default Re: Saginaw 4 Speed Cluster Gear Help
You don't need it. I think it was suppose to stop rattling noises in the transmission.
Old Apr 3rd, 10, 07:07 PM
Joel
Thanks. As soon as I get my case back I will start putting it back together!
Old Apr 3rd, 10, 08:52 PM
mrmuncie's Avatar
mrmuncie mrmuncie is offline
Lee
Even though the "chater plate" was ment to keep chater down when it is worn(rivets pull out and becomes a real noise maker)
Your much better off without one.
Lee (in Louisville, Ky)
Second owner 69 SS Camaro 350 A/C Stick
I specialize in Muncie 4 speeds. Rebuilding tranys for 20 years with over 50 Muncies to select from. If your looking for a certian date code I should be able to help.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: Saginaw 4 Speed Cluster Gear Help
Location
Location
First Name
Human Verification
