67 RS conversion - Team Camaro Tech
Body Shop Paint & Body Forum
Old Apr 24th, 10, 05:40 AM
CamaroJim CamaroJim is offline
Tech Team
Default 67 RS conversion
I have a 67 ragtop and am considering cloning it to an RS body style. I know the front and rear valence need to be changed to accept RS reverse and parking lights. I know the tail lights need to be changed to RS tail lights along with painting the rear panel black. What is involved with swapping headlights and grill? Do the fenders need to have additional brackets? Anything else I'm not thinking of?
67 SS Clone, Drop Top, 327, Edlebrock heads, M-22, 3:73 posi, red / black bumble bee stripe
69 Coupe, 383, Dart heads, TKO 5-spd, 3:73 posi, white / red stripes
02 SS, Drop Top, 6-spd, SLP goodies, black on black
Old Apr 24th, 10, 06:43 AM
shoe shoe is offline
Jeff
Default Re: 67 RS conversion
You will have to either change the fenders for the RS headlight assembly or modify yours with the "brackets" to set them back deeper into the fenders. Of course the whole headlight and grill assemblies have to be changed as well. Yes, the valances have to be changed, I wouldn't recommend trying to cut them out to accept the lights.
On the black back panel, I thought that was an SS option not RS, but I might be wrong on that.
-shoe
Current Projects - See my albums
68 Coupe Restomod (7-2010 to ???)
67 RS/SS Convertible project (8-2007 to ???)
Old
67 SS 396 Coupe (sold 7-12), 68 SS 350 (sold 2-12), 68 383 stroker (sold 10-09), 68 SS 350 TPI (sold 2006), 69 SS 350 (sold 1987), 68 327 (1980 Bench seat column shift), 89 RS (son totaled), 88 IROC (son totaled), 76 LT1 (roommate wrecked)
Old Apr 24th, 10, 07:23 AM
67motorcat 67motorcat is offline
Steve O.
Front fender brackets are available to convert to RS through vendors.
Blacked out back panel was a big block only thing,even if RS...but looks cool on any car.
The rear Valance will have to be cut for the reverse lights,I believe even the replacment rear Valance available does not have the cutouts for the reverse lights as well.
67' Vert RS Tremec TKO- Eaton 3:55- 350 cu.- L98 heads-Vintage Air- Torque Thrust-BFG.g-force 4-wheel disc.
Old Apr 24th, 10, 09:11 AM
AintQik AintQik is offline
You will also need a new wiring harness for the front and all the junk that goes with it. Relay panel etc. New tail lights, holes in the trunk for the back up lights, different hood release, it gets pricey. I have a buddy in the parts business that does this and he can help get a parts list you need together. Many of the "complete" kits aren't that complete.
rj
Old Apr 24th, 10, 10:12 AM
keypilot's Avatar
keypilot keypilot is offline
Mark
steves camaro offers the most complete kit that i found. mine is an "after the fact" RS. my tailpan was cut to accept the lights.
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
499 lb-ft @ 4,800 rpm
www.firstgens.com
Old Apr 27th, 10, 09:25 PM
Jeff
Classic carries a "made in USA" rear RS valance I see, but OUCH at $490. Then there's the inner rear panel which is another $75. The RS headlight brackets are only $28 a pair.
Old
Old Apr 27th, 10, 10:51 PM
BPOS BPOS is offline
Al
I did it on my 69. Not that tough. On your 67, if you don't care about factory correct, I'd consider one of the aftermarket headlight kits that does away with the problematic 67 electric system. No limit switches, all electronic. The actual install of the the grill, buckets, etc is pretty straightforward, but since it's likely all repro stuff, expect to tweak things a bit. Blacked out tail panel is for SS Big Block only, to be correct.
The tail panel will need to be cut for the backup lights. I seem to recall that the 67 needs to have the inner panel cut as well, but not sure. I bought a $20 HF body saw and a template kit from Ricks for the tail panel holes. Laid down some blue tape, marked it all out over the tape, drilled a pilot hole and cut away on a painted panel. Turned out great w/o damaging surrounding paint. Treated the bare edges w/touchup paint. Dimples already in the trunk pan to locate holes for the wires, soldered up a couple wires for the b/u lights. Pretty darn easy. Sold the template kit so the next guy could use it. Certain that the purists are cringing.
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
