1968 CAMARO FRONT SPRING EYE BRACKET Bolts missing ???? - Team Camaro Tech
Old Apr 27th, 10, 08:54 PM
70ChevelleLS5 70ChevelleLS5 is offline
Team Member
Rob
Default 1968 CAMARO FRONT SPRING EYE BRACKET Bolts missing ????
I just picked a 68 RS-SS Camaro and after looking under neath the car I noticed the front bolts in the FRONT SPRING EYE BRACKETS were missing, It almost looked like someone cut a hole were the nut should be on the body. anybody see this before?
Old Apr 27th, 10, 10:01 PM
Jess67 Jess67 is offline
Jess
Default Re: 1968 CAMARO FRONT SPRING EYE BRACKET Bolts missing ????
They have a j nut that slips on the metal. Then the bolt screws into it. They are bad to rust and break when trying to replace the rear end. They make them repro. Two of mine broke, just replace them with the new bolts and nuts. I put the blue thread lock on them, and then coated with white grease once put in to keep from rusting agian...
Jess67
67 Camaro Blue 427, 4-speed, 12 bolt
67 Camaro 350, 200-4R, PS, AC, PB, IN PARTS
Old Apr 27th, 10, 11:01 PM
impreza13 impreza13 is offline
not sure on the torque specs for the j nuts but be careful when tightening them i had a couple new ones break on me. i was going to try and make something different for them if i cant get some more new ones to snug up.
Rich
67 that is asleep right now but is somehow my dream
