seat belt retractor recoil band - Team Camaro Tech
Old May 1st, 10, 04:49 PM
VintageAgain VintageAgain is offline
Rich
Default seat belt retractor recoil band
Anyone every disassemble and reassemble the recoil mteal band in a retractor? I accidently opened one side of the seat belt rubber trim and it popped out!
1968 Camaro; 350/th-400
Old May 1st, 10, 06:13 PM
KevinW's Avatar
KevinW KevinW is offline
Kevin
Default Re: seat belt retractor recoil band
Yes, I have restored them. Just coil it back up while you test it to get the correct tension. You must have cut the cover the see the spring.
Old May 4th, 10, 08:11 PM
jameyw00 jameyw00 is offline
I have found that putting some grease between the retractor cyclinder and metal bracket helps a bunch. This keeps the retractor retracting all the way back up, eliminating hitting the buckle on the side of the car!!
