How to make cast aluminum look new? - Team Camaro Tech
Thread Tools Display Modes
Old May 9th, 10, 03:57 PM
Seven Seven is offline
Default How to make cast aluminum look new?
I have a set of aluminum heads that are a bit dirty, greasy and have some paint on them. What is the best way to clean them up, get them looking new again and keep them looking new?
Old May 9th, 10, 04:42 PM
DenRS's Avatar
DenRS DenRS is offline
Default Re: How to make cast aluminum look new?
I used mothers chrome/wire wheel cleaner on my cast aluminum intake and it removed rust and fuel stains. Edelbrock recommended that for cleaning my intake. Worked pretty good.
1969 Camaro 350, Trickflow heads, ST-10 4spd, Hotchkis suspension, Baer SS brake kit, moser 12bolt
Old May 9th, 10, 05:32 PM
1967 Plum 1967 Plum is offline
Dee
I have some old cast aluminum Holley valve covers that were grimy/dirty and had been painted at one time. I soaked them in my parts cleaner for a couple of days. Then I coated them with a citrus-based paint stripper from Wal-Mart. After that I shot them with brake cleaner and used towels and q-tips to clean them off.
Now they look really good but I need to buff them. I'm going to use a buffing wheel on my grinder along with some buffing compound. I expect them to look pretty good when I'm done.
1967 RS/SS350 Camaro (mostly stock)
1969 RS/SS Camaro (being improved!)
Old May 10th, 10, 09:48 AM
Moonpie's Avatar
Moonpie Moonpie is offline
Mickey
Bead blasting works wonders.
Old May 10th, 10, 02:26 PM
Steptoe Steptoe is offline
Steps
Old school version, clean all paint and crap off...stripper etc
The soak in a soln of cirtic acid...1 teaspoon per cup warm water
Citric acid will be found in the wifes spice cupboard, or spice shelf at the supermarket
Painting on and keep damp for a couple hrs, wash off
Good for restoring old vintage carbs, bell housing, anything Aluminum
Old May 11th, 10, 05:45 AM
Busted Knuckles Busted Knuckles is offline
I always use something to remove all the oil and residue first - a really good bath in the parts cleaner followed by an acetone bath. After that's all gone and rinsed, the citrus cleaners do a good job on anything water based. They're not effective on petroleum based residues, or at least the ones I've tried weren't.
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
Old May 11th, 10, 05:50 PM
Steps
The citric acid reacts with the top molecular layer of the Aluminium removing any oxidation.
One can use any acid, but the trouble with stronger acids like H2SO4 (battery acid) and HCL they are extremely reactive with aluminuim and corrode the surface way too deep.
Old May 11th, 10, 09:36 PM
BPOS BPOS is offline
Al
After several attempts over the years to make aluminum intakes look new again and keep them looking that way, I finally figured it out. I painted it black. It looks good, plus I don't drive too much with the hood up.
69 PJ Convert, RS added, 383, Pro-Filer 195s, 2004R, 3.73 posi 8.5, C6/LS1 Brakes, etc "Big hitter, The Lama....long." Carl Spackler
Old Jun 15th, 10, 06:38 PM
Myfirst 69SS Myfirst 69SS is offline
Mark
What would the citric acid trick do to my Z28 finned valved covers?
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
Old Jun 15th, 10, 10:36 PM
Steps
Gives them the orginal grey look
  #11
Old Jun 16th, 10, 05:49 AM
ZZ_430's Avatar
ZZ_430 ZZ_430 is offline
Don
Soda blasting.
Don ~ TC Member #15 ~ http://www.flickr.com/photos/46701464@N06/sets/
Don't mess with Texas!
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: How to make cast aluminum look new?
Location
Location
First Name
Human Verification
