What's the best way to raise the rear of my '78 Camaro 1 to 2 inches? - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
Thread Tools Display Modes
Old May 21st, 10, 12:29 PM
NYH1 NYH1 is offline
Tech Team
Alex
Default What's the best way to raise the rear of my '78 Camaro 1 to 2 inches?
My '78 came with 195/75-14 tires on it when I bought it. The car sat a little lower in the rear.
I traded the 14x7 wheels and tires for a set of 15x7 Z28 5 Spoke Mag wheels. I'm going to use Mastercraft Avenger G/T tires. They're T speed rated. I run their Courser A/T2 on my truck and love them.
Anyway's I want the rear to sit a tad higher then the front. I'm going to put all new springs on it, but that won't be any time soon.
My front tires will be 235/60-15
26.11" tall
9.15" section width
7.6" tread width
on a 15x7 wheel
My rear tires will be 255/60-15
27.1" tall
10.24" section width
8.2" tread width
on a 15x7.5 wheel.
The rear tire are only going to get me about a 1/2 inch more height. What else can I do to safely gain another 1" or 1 1/2" of height in the rear?
Thanks, NYH1!
'78 Camaro, mild Vortec head 385 stroker motor, TH350 w/ Coan 11" 2600 stall, 8.5" 10 bolt w/3.42 posi, 1 5/8" full length Hedmen Headers, 2 1/2" full length Flowmaster dual exhaust system. Going to be a daily driver/mild street performance car!
Old May 21st, 10, 12:32 PM
SPARKY69's Avatar
SPARKY69 SPARKY69 is offline
BILL
Default Re: What's the best way to raise the rear of my '78 Camaro 1 to 2 inch
air shocks or buy new rear springs..
BILL D.
JOHN 3:16
SEMPER FI
if you have a bbc in your 1st gen 67-69 camaro click on the link below and enjoy the veiw and post yours up!!
http://www.camaros.net/forums/showthread.php?t=169199
if you have an all original 1st gen camaro 67-69 click on the link below and enjoy the veiw and post your up!!
http://www.camaros.net/forums/showthread.php?t=179697
Old May 21st, 10, 03:11 PM
Legacy 69's Avatar
Legacy 69 Legacy 69 is offline
Rick
Air shocks will give you a real s*** ride, i would suggest adding one long leaf or adjustable coil over shocks. Adding the long leaf is a simple fix with a set of torches to heat the nuts, an impact gun and couple of c-clamps. Purchase a new pair of center bolts and your away to the races. Where do I get the long leaf you ask, go to your local auto wrecker and ask them to cut a set of leaf packs out of a vehicle with leaves the same width as yours. This way you have an assortment of lengths to try until you get the height you wish. This will make a noticeable improvement in your ride and change the vehicles handling so be careful.
Legacy 69
Old May 21st, 10, 10:03 PM
1971BB427 1971BB427 is offline
Vall
Air shocks and longer spring shackles. As mentioned, air shocks have a reputation for harsh ride, but you can avoid the harsh ride by going with a slightly longer spring shackle. The combination will allow the air shocks to slightly raise your rearend without binding the springs and causing the harsh ride.
I put air shocks on my 1971 back in 1975 when I was racing it. I still run them and they have a great ride if properly set up. I also have dual fill lines so I can preload my suspension when drag racing. I put slightly more air in my right rear to keep the car from coming up to hard on the left front. Additionally I run a shock extension on the bottom of the shocks so they stay in the middle of their travel range and don't need to be pumped to high pressures to work well.
1971 SS427 Camaro. 2nd owner since 1973!
Old May 21st, 10, 10:52 PM
Jeremiah Jeremiah is offline
I recently pulled a set of gas charged rear shocks off my 69 with hopes of the rear dropping an inch and it worked.
Try some heavy duity gas charged shocks?
1967 Camaro in the works-406 AFR 210E Chassisworks subframe, 13" wilwood.
69 Camaro SS/RS, Orange/white, Ivory houndstooth/VE3.. sold
Old May 23rd, 10, 06:45 PM
RichSchmidt RichSchmidt is offline
Rich
There is nothing wrong with a properly set up pair of lift shackles.I use them on my race car,just not in the highest setting.They ae strong,and come with new bolts.I cut the ones I use so that any excess that extends past the bushings is gone.Technically it would seem that they would drive the pinion angle up,but since the body is moving away from the axle you need the pinion to turn up a bit anyhow.
Now the problem is that if your car isnt high enuff to clear stock Z/28 wheels and tires{they actually used lowering springs on later Z's) you may have a broken spring.Springs break in the middle under the rear axle pads and you cant see it,but if they are broke,and usafe shackles will only make things worse.Check before you put yourself at risk.
Old May 23rd, 10, 07:46 PM
Vall
I don't care for all the adjustment holes hanging down on aftermarket shackles so I just made up a pair that were 2" longer than stock, out of flat bar.
Old May 23rd, 10, 08:21 PM
Rich
Yeah Vall,thats why I cut all the extra holes off mine,but the are hard to cut.The first time I did it as a kid I caught heck for ruining my father' very expensive band saw blade
Old May 25th, 10, 09:55 AM
Tech Team
Alex
Thanks guys!
Old May 26th, 10, 03:47 PM
Vall
I bet you did! Those factory made shackles are made of some really tough material! I chopped the extra holes off a set with my portaband and it pretty much chewed all the teeth off!
  #11
Old Jun 18th, 10, 09:34 AM
middleagecrisis middleagecrisis is offline
Tom
Go to an industrial spring shop and get a 3/4 length leaf and add it too your existings springs. You'll have to unbolt the rearend and possibly get new U-bolts, however, you'll increase your traction and raise the car at least an inch. You can also have the same shop re-arch your springs. I've done both methods to raise or lower a car (by removing a leaf). Adding an extra spring or two also increases your off-line traction and adds to cornering ability. IMHO, adding longer shackles makes a camaro look to ghetto . It's a little more work to do it my way, but you'll be happier with the results and it's no more expensive than a set of air-shocks. For ultimate traction, add urethane spring bushings and an extra leaf! I did this to a modified big-block four-speed car and got instant traction with no other changes!
  #12
Old Jun 18th, 10, 02:39 PM
arocars arocars is offline
Try air shocks or simply use shock extenders. Mr. Gasket sells them. If you do a search, I recently posted a part number for them.
  #13
Old Jul 7th, 10, 03:01 PM
CamaroDoc CamaroDoc is offline
Tech Team
Britt Smith
I use Gabriel HiJackers on my 72 RS. Monroes are too short. You have to air them all the way up to gain any height and it's like riding a buckboard wagon. HiJackers are a little longer and will allow you to lift the rear without topping them out with extreme air pressure. My 72 rides just fine like this, corners great, and hooks fairly well on launch unless I just blow the tires away completely...
  #14
Old Jul 8th, 10, 12:13 AM
braber427 braber427 is offline
Tech Team
Bill
Air shocks give a harsh ride. Longer shackles change the ride/handling geometry and can look odd with the extra metal hanging down, plus the question of stability and possible breakage due to the aded height The recommendation I got was to do one of two things: replace the old, sagging original springs with new. Or, two, have a spring shop add an extra leaf to the existing springs -- it will stiffen the ride somewhat, however.
I went with replacing the old springs with brand new. Worked fine!
Hope this helps!
Bill
'69 375/396 TR 711 71 06A X22D80
LeMans Blue
'55 Chev PU Napco (Original)
350 Bright Yellow
Team Camaro Tech > Generation Specific Forums > Second Generation      Current Topic: What's the best way to raise the rear of my '78 Camaro 1 to 2 inches?
Location
Location
First Name
Human Verification
