What shifter to use with 6L80 trans conversion? - Team Camaro Tech
Pro Touring Todays performance with classic style
Thread Tools Display Modes
Old May 23rd, 10, 04:43 PM
Ross Racing Ross Racing is offline
Tech Team
Default What shifter to use with 6L80 trans conversion?
I am doing a LS3/6L80 conversion into a 67 camaro and the factory auto shifter from a 2010 is way too tall and would require a custom console to look decent. Due to its design and size it can not really be modified. I am looking for an aftermarket auto 6 speed shifter for the 6L80 that is shorter and less bulky.
I know the 09 CTSV has the same trans, but I don't know if the shifter is any smaller. Does anyone have any suggestions or ideas?
Worst case I will have to modify the tunnel to relocate & drop the shifter . The tunnel had to be raised nearly 2" in order to get the trans mounted properly.
I know some people like Prodigy Customs have done the conversion before. What shifter did you use.
Did you need a custom console?
Dave
1967 Camaro, Indigo blue, LS3 & 6L80 trans
http://s496.photobucket.com/albums/r...0LS3%20Camaro/
2009 Cadillac CTSV Kooks headers with Corsas, intake, tune, 20" Forgeline ZX3p's 532 rwhp/517 rwtq
Old May 23rd, 10, 05:00 PM
john68 john68 is offline
John
Default Re: What shifter to use with 6L80 trans conversion?
Cut the shifter and shorten it??
Old May 23rd, 10, 05:05 PM
Tech Team
Due to the mechanics and design of the shifter it doesn't appear to be customizable.
As I previously said.
Old May 24th, 10, 04:17 PM
NOR_CAL_67rs NOR_CAL_67rs is offline
Nevin
Did you look at any short throw shifters? Would one lower it enough? there are a few out there...
Old May 24th, 10, 05:31 PM
68problemchild 68problemchild is offline
Patrick
Various options:
http://www.shiftworks.com/kits.htm
John at speartech has a new custom 6L80 Dual gate tap shifter. click on LS-58X and scroll down.
http://www.speartech.com/
F1 type for steering wheel. I think its called a "shrifter". This thing rocks.
http://twistmachine.com/shopping/ind...&products_id=6
1968 Convertible L92 VVT project, Hotchkiss lowering front & rear.
http://www.flickr.com/photos/41575483@N07/?saved=1
Old May 27th, 10, 12:14 PM
TLE67396L78 TLE67396L78 is offline
I think you could use a 67 camaro powerglide shifter....The 6L80E has 5 positions just like a powerglide. You need P R N D S (S= sport mode, which is you shifting up and down ...with say a paddle shifter option mounted to your steering wheel) You could use a stock console in this option. Im wanting to do one of these swaps as well. Going to follow your thread here, or do you have a build thread some where?
The speartech shifter looks cool also....!!
Old May 27th, 10, 01:34 PM
Tech Team
The Speartech is also large(09 CTSV) and would require a custom console. I am going with a bump shifter(tap) from a non sponsorng vendor. I should then be able to use my OER console. Not sure yet how much if any modification will be required. I think I want to stay away from paddles, but haven't made up my mind.
Old Nov 12th, 14, 09:10 AM
Hybrid 69 Hybrid 69 is offline
Brad
i know this thread is ancient but Ross Racing, can you give a little more info about what shifter you went with?
Team Camaro Tech > All Generations > Pro Touring      Current Topic: What shifter to use with 6L80 trans conversion?
Location
Location
First Name
Human Verification
