| Team Camaro Tech Current Topic: master cylinder actuator rod purchase | ||
| Brakes, Suspension & Steering Conversion questions, Steering & Handling |
#1 Denvervet Registered User Join Date: Sep 2007 Location: Denver Posts: 157 Trader Rating: (1) I purchased an aftermarket master cylinder and a hydroboost from a 2002 Escalade and now I find neither has the actuator rod that depresses the master cylinder from the booster. Both master and boost have the depression in the piston but not even sure if it is a boot that holds it in place. I need to know where I can purchase the rod and whatever boot etc to hold it in place. Any ideas?
68 coupe ,572,tko |
| Sponsored Links | ||
Advertisement | ||
I'm pretty sure I have a new one you can have but you will need to know the length you need ro make sure it would work.
1959 Pontiac Catalina 389 tri power ![]() 1967 Camaro Convertible ordered from Spain docs 1969 Camaro cpe with POP 1969 Camaro cpe 57K orig mile w/window sticker &POP 1999 Acura 3.5RL 1999 Southwind 32V 2000 Tundra V8 2008 Tundra bigger V8 |
Thanks, I will measure and let you know. Is there a boot or sleeve that holds it in place?
68 coupe ,572,tko |
| Sponsored Links | |
Advertisement | |
