MSD ignition wiring question - Team Camaro Tech
Old Jun 3rd, 10, 10:29 PM
zlek131 zlek131 is offline
Matt
Default MSD ignition wiring question
Using the diagram below to wire in my MSD 6al-2 to MSD 85551 dizzy. Couple questions:
Should I fuse the two power wires going back to battery (heavy red and blue 2-step/launch). If so, what AMP fuse for each?
If fusing is a must, could I splice the two power wires above together and fuse with single fuse? (running out of space on the power distribution block...) If so, what AMP fuse for combined wires?
Last, heavy black to battery negative, can I just ground it to some good ground near by or do I need to run it all the way back to the battery negative post?
Matt
68 RS
72 RS/SS
Go for a 68 ride
Old Jun 3rd, 10, 10:42 PM
Matt
Default Re: MSD ignition wiring question
Answered one of my own questions... Blue 2-step limit must be activated via a switch, so splicing the blue and red together as one is not an option. So back to the fuse question should each be fused?
Matt
68 RS
72 RS/SS
Go for a 68 ride
Old Jun 4th, 10, 03:32 AM
Everett#2390's Avatar
<Jake 68's Rule
By trial & error, you tried tying the two together and found it 2-stepped all the time.
No fuses required in either as the launch switch would be from a fused source, maybe, dependent upon installed option.
You can run the large neg wire to the block and the large red wire to the solenoid post if on the firewall or to the battery posts if mounted on the inner fender. For best operation, both to battery posts.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
